Just some questions I might ask if I were given these instructions.
● Create a new project directory on C:\ called E12-345
Do you want it in the root of C or do you have a specific place on the C drive you would like it created? Do you prefer the project directory be read only for all users except "current user", or should I presume that all local users have rights to modify these files, also, should I publish this project directory to the LAN and/or WAN and/or WLAN so other users will have access to them, and if so, what rights should I allow for these users?
● Start AutoCAD and recreate the drawing included with handout
Will a complete 3d model be required or would you prefer a 2d representation or isometric view? Do you have a specific template you would like me to use? A specific title block? Do you prefer MS or PS?
● Print drawing to scale
What scale? What size paper? Do you prefer a MS plot or a PS plot?
● Create mock timesheet in Excel, using functions to calculate hours for a week
Do you want the Excel timesheet to cover only this particular project, or would you like it to have entries for multiple projects, so that you can readily see how my time in the office was split among projects? Would you prefer to see the days split among different worksheets or would you prefer different projects be assigned their own worksheet within the spreadsheet?
● Create Zip file, containing the drawing and the timesheet and e-mail it to _____________
What compression factor would you prefer I use? Should I presume the recipient does not have all of the shapes and fonts, and thus include them in the compressed archive? Would you like the DWG file sent in an editable format or one that is not readily editable without special knowledge or special programming?
What would you like for me to do for the remainder of the alotted time for this project?
