Author Topic: New Lisp any suggestions are welcomed  (Read 20353 times)
Re: New Lisp any suggestions are welcomed
« Reply #60 on: October 22, 2010, 05:49:51 PM »
Thank you, I think found the eBook on googlebooks.
« Reply #61 on: October 22, 2010, 05:53:06 PM »
< .. > I like that.  <..>
I don't.
Ah, I had hoped you would chime in. ...speaking of the author making you think.
*lol*
alanjt
  • Standby for witty remark...
« Reply #62 on: October 22, 2010, 05:56:24 PM »
Next up: Sartre and Heidegger!
Dropbox
« Reply #63 on: October 22, 2010, 06:02:59 PM »
*lmao* Hold on there cowboy! I need to learn to program and read as many classics as i can too (not the mention the minutia of life).
However, be warned that I AM gonna start to tap your brain.
alanjt
« Reply #64 on: October 22, 2010, 06:06:01 PM »
Shit, I'd better dig up my copy when I get home.
Dropbox
cmwade77
« Reply #65 on: October 22, 2010, 06:52:29 PM »
Honest question:
Why do you care?
I would say there are a couple of reasons to care:
  • If I know where blocks of code came from, then I know how reliable it is, for example there are those on here that I know their code will work and work well.
  • If I don't understand exactly how some of the code works, but I do know who wrote it, I have found that I can usually ask them questions about it and understand it better, so that I know how to do something that I didn't before.
  • It is a matter of acknowledgement, I mean sometimes people spend hours of their time making these routines and acknowledgement of that work can be nice. Luckily, when I have downtime at work, I can work on these to make everyone more efficient here.
  • It is just the right thing to do, otherwise it looks like you did all of the work yourself and that is not fair to others.
Well, that's my honest answer for the honest question, hope it makes a little more sense now.
« Reply #66 on: October 22, 2010, 07:45:30 PM »
Honest question:
Why do you care?
<snip>
And those are all valid. I wholeheartedly agree with `giving credit where credit is due' (I wasn't making an argument against that at all).
« Reply #67 on: October 22, 2010, 08:11:11 PM »
So there are 2 discussions : copyright and good manners. ?
http://www.templetons.com/brad/copymyths.html
I know nothing about good manners and less (with certainty) about copyright.
Has anyone looked at some of the AutoDesk sample code for copyright notices recently ...
or seen the legal notice that the ARX wizard includes(inserts) into our code header ??
[edit: MindInNeutralSpelling]
« Last Edit: October 22, 2010, 09:17:55 PM by Kerry »
« Reply #68 on: October 23, 2010, 11:01:29 AM »
I haven't. Can you post the ARX wizard one if you have it? I will go look for the sample code.
« Reply #69 on: October 23, 2010, 11:11:38 AM »
HasanCAD
« Reply #70 on: October 24, 2010, 06:35:46 AM »
First of all I am sending my apology to all for misunderstand.
Who will read the lisp, will find that I am adding the copyright to all just proud with my lisp no thing else
I would not and will not ascribe any work for me and proving for that see this post
http://www.cadtutor.net/forum/showthread.php?53532-How-to-Insert-the-Layer-Using-Lisp&p=362865&viewfull=1#post362865
 I added
(defun makelay (LName LColor LType)
;  CAB
I added a part copied from CAB so I added his name
One more thing
For uFlag
This issue had been mentioned before by you
http://www.theswamp.org/index.php?topic=34005.msg393524#msg393524
Let's take a look at the post
-   The main routine and all subroutine is copyrighted but *error* doesn’t have because it is not mine
-   Copyright added to HSN:TL-Line subroutine, who thinking that that subroutine worth to be as a subroutine but I am training myself to do what LEE mentioned before to use subroutine.
This is a new lisp
Any suggestions are welcome
Sorry for native language its explanation of the lisp
(defun c:TanLine (/ p1 p2 p3)
  ;Copyright © by HasanCAD
 (defun *error* (msg)
  (and uFlag (vla-EndUndoMark doc))
(defun HSN:DDwnMnuSetSysVar ()
 (defun HSN:ReDDwnMnuSetSysVar ()
(defun HSN:TL-Text ()
(defun HSN:TL-Line ()
       (entmake (list
  (cons 0 "LINE")
                  (cons 10 p1)
                  (cons 11 p2)
I hope that I clarified the misunderstand
