Author Topic: entmake SECTIONOBJECT - DXF62 does not work  (Read 2068 times)
Peter2
« on: February 08, 2018, 11:50:32 AM »
This code (nearly) works for me:
(entmake
            (list
                '(0 . "SECTIONOBJECT")
                '(100 . "AcDbEntity")
                '(100 . "AcDbSection")
                '(67 . 0)
                '(410 . "Model")
                '(8 . "Schnitt")    ; Layer
                '(90 . 1)    ; 1=Ebene
                '(91 . 5)    ; 1=Liveschnitt; 5=verkehrter Blick
                '(1 . "v1")    ; Name
;                '(10 0.0 -1.0 0.0)   ; vertikale Richtung für hor. Schnitte
               '(10 0.0 0.0 -1.0)   ; vertikale Richtung für vertikale Schnitte
                '(40 . 10)      ; Höhe oben = rechts von der Basislinie
                '(41 . 5)      ; Höhe unten = links von der Basislinie
                '(70 . 5)           ; Transparenz
                '(62 . 1)        ; Farbe rot
                '(92 . 2)                ; Anzahl Scheitelpunkte
                                         ; Kontrollpunkte für Hinterlinien (wiederholt für Anzahl der Kontrollpunkte für Hinterlinien);
                '(11 -5 3 2)  ; Z= SchnitthöheStartpunkt der Basislinie
                '(11 5 3 2)   ; Zielpunkt der Basislinie
;                 '(93 . 0)
The only thing that does nearly nothing - no result, no error - is DXF 62 with value 1 (red).
Only the "baseline" of the sectionobject is created in red, the "area" of the object is always created in standard-color grey (colour 9).
Any ideas where the problem is?
Peter
BricsCAD V23
Re: entmake SECTIONOBJECT - DXF62 does not work
« Reply #1 on: February 08, 2018, 12:03:29 PM »
Try this:
(entmake
(67 . 0)
(410 . "Model")
(8 . "zDtl xLight 3")
(62 . 1)
(90 . 1)
(91 . 1)
(1 . "v1")
(10 0.0 0.0 -1.0)
(40 . 10.0)
(41 . 5.0)
(70 . 5)
(62 . 1)
(92 . 2)
(11 -5.0 3.0 2.0)
(11 5.0 3.0 2.0)
(93 . 0)
ribarm
  • Marko Ribar, architect
« Reply #2 on: February 08, 2018, 02:08:20 PM »
But section object is designed as line which is movable... So when you change color to it, that entity is changed... You can't affect default fill color of sections - they are always grey...
M.R. on Youtube
Peter2
« Reply #3 on: February 08, 2018, 04:44:02 PM »
@CAB
thanks, I will try tomorrow.
...You can't affect default fill color of sections - they are always grey...
But the colour can be changed manually after creation. Maybe that's the only way?
Peter
BricsCAD V23
Peter2
« Reply #4 on: February 09, 2018, 03:32:48 AM »
Try this:...
:-( As ribarm already noted - it does not work.
Peter
BricsCAD V23
Peter2
« Reply #5 on: February 09, 2018, 09:48:04 AM »
Hmm - Bricscad accept the following code and creates a green "base-line" and a red "area"; AutoCAD ignores the color of the area:
  1.             (list
  2.                 '(0 . "SECTIONOBJECT")
  3.                 '(100 . "AcDbEntity")
  4.                 '(67 . 0)
  5.                 '(410 . "Model")
  6.                 '(8 . "0")    ; Layer
  7.                 '(62 . 3)       ; Farbe der Linie
  8.                  '(6 . "DASHED")
  9.                 '(370 . 100) ; Linienstärke
  10.
  11.                 ; dieser 100er muss er nach den Eigenschaften der Linie kommen
  12.                 '(100 . "AcDbSection")
  13.                 '(90 . 1)    ; 1=Ebene
  14.                 (cons 91 0)    ; 1=Liveschnitt; 5=verkehrter Blick
  15.                 ;(cons 91 code_91)    ; 1=Liveschnitt; 5=verkehrter Blick
  16.                 (cons 1 name)    ; Name
  17.                  (cons 10 code_10)
  18.                 (cons 40  code_40)      ; Höhe oben = rechts von der Basislinie
  19.                 (cons 41  code_41)      ; Höhe unten = links von der Basislinie
  20.                 '(70 . 5)           ; Transparenz
  21.                 '(92 . 2)                ; Anzahl Scheitelpunkte
  22.                 (cons 11 code_11a)  ; Z= SchnitthöheStartpunkt der Basislinie
  23.                 (cons 11 code_11e)   ; Zielpunkt der Basislinie
  24.                 '(62 . 1)        ; Farbe rot
  25.             )
  26.     )
Peter
BricsCAD V23
Peter2
« Reply #6 on: February 26, 2018, 02:54:49 AM »
Here is a current blog from Autodesk Dev Blog, which confirms that is does not work in pure Lisp, but works with ActiveX
http://adndevblog.typepad.com/autocad/2018/02/create-section-object-using-vlisp.html
Peter
BricsCAD V23
