Author Topic: CHPROP on (entlast) after GUI command INSERT  (Read 1484 times)
Marc'Antonio Alessi
  • Marco
« on: February 21, 2020, 09:13:41 AM »
; simple example:
(defun ALE_Block_Draw_Insert (NewLyr / LstEnt)
  (if (> (atof (getvar "ACADVER")) 23.0)
    (command "_CLASSICINSERT")
    (progn (initdia 1) (command "_.INSERT"))
  (setq LstEnt (entlast))
  (command "_.CHPROP" LstEnt "" "_LAYER" NewLyr "")
in this sample (entlast) refers to the last entity before the command.
V-Man
Re: CHPROP on (entlast) after GUI command INSERT
« Reply #1 on: February 21, 2020, 09:41:32 AM »
Maybe
(command ".chprop" "last" "" "_LAYER" NewLyr "")
ribarm
  • Marko Ribar, architect
« Reply #2 on: February 21, 2020, 09:47:30 AM »
Maybe :
  (while (< 0 (getvar 'cmdactive)) (command "\\"))
M.R. on Youtube
Marc'Antonio Alessi
  • Marco
« Reply #3 on: February 21, 2020, 10:19:12 AM »
Marko, V-Man thanks, both of your solutions seem to works properly.
