Author Topic: AutoLoader for MgdDbg  (Read 23557 times)
Re: AutoLoader for MgdDbg
« Reply #15 on: October 29, 2013, 10:48:08 PM »
For fun could create our own and call it SnooperPooper.
If you have ever looked at autocad's managed assemblies with Reflector or ILSpy I am sure you have seen all those Categories Attributes.
With no customizing and just adding a PropertyGrid from Extended WPF Toolkit™ Community Edition you get this much from 1 line of code or setting its selected object property.
Code - C#: [Select]
  1.     public partial class PropWindow : Window
  2.     {
  3.         public PropWindow()
  4.         {
  5.             InitializeComponent();
  6.             propGrid.IsReadOnly = true;
  7.         }
  8.         public PropWindow(DBObject dbo) : this()
  9.         {
  10.             propGrid.SelectedObject = dbo;
  11.         }
  12.     }
  13.
Xaml
Code - XML: [Select]
  1.
  2.  <Window x:Class="_Alpha_HpadCad.App.UI.Windows.PropWindow"
  3.        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
  4.        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
  5.        xmlns:xctk="http://schemas.xceed.com/wpf/xaml/toolkit"
  6.        Title="PropWindow" Height="388.083" Width="517.322">
  7.     <Grid Margin="1,1,1,1" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" >
  8.         <xctk:PropertyGrid x:Name="propGrid" HorizontalAlignment="Stretch" HorizontalContentAlignment="Stretch" VerticalAlignment="Stretch" VerticalContentAlignment="Stretch" Margin="1,1,1,1">
  9.         </xctk:PropertyGrid>
  10.     </Grid>
  11. </Window>
  12.
WILL HATCH
« Reply #16 on: October 29, 2013, 10:49:42 PM »
I did not, you're probably right. I was using it to monitor all events when I closed autocad and it crashed. Best guess is there wasn't an editor to write out the data.
WILL HATCH
« Reply #17 on: October 29, 2013, 10:51:54 PM »
Very nice, your usage of wpf always impresses
« Reply #18 on: October 30, 2013, 12:10:06 AM »
Just running past Jeff ..
Have you changed your build to use the WPF?
I'll have a look when I get a chance, but you'll probably answer before that happens :-)
gile
  • Marseille, France
« Reply #19 on: May 20, 2014, 08:50:27 AM »
I finally took the time to update this tool for 2014 and 2015 versions . I did not make an installer, just extract the folder "Autodesk DWG MgdDBG.bundle" in the directory plug-ins: "%appdata%\Autodesk\Plug-ins" (rename the previous folder if it was already installed).
I have not thoroughly tested or corrected all existing bugs in the original version. I only did the necessary changes to compile the DLLs with the libraries of each version from AutoCAD 2012 to 2015.
Download MgdDgb.zip.
<EDIT> repared above link.
« Last Edit: May 20, 2014, 04:13:28 PM by gile »
Keith Brown
« Reply #20 on: May 20, 2014, 03:28:27 PM »
Hi Gile,
Thanks for updating for 2015.  I tried to download the file and it is not found on your server.
BlackBox
« Reply #21 on: May 20, 2014, 04:02:58 PM »
Hi Gile,
FWIW - I downloaded it from here earlier today.
gile
  • Marseille, France
« Reply #22 on: May 20, 2014, 04:13:56 PM »
I repared the link.
huiz
  • Certified Prof C3D
« Reply #23 on: July 17, 2015, 07:13:57 AM »
Thanks to the effort by gile, it was quite easy to rebuild this for 2016.
Here you can download the complete source and bundle data. I also did not create an installer, just save the bundle at the location described above.
edit: Another download link
« Last Edit: July 26, 2015, 05:42:46 AM by huiz »
BlackBox
« Reply #24 on: July 17, 2015, 08:55:52 AM »
Merci, Gilles... Y gracias, Henrique! :-)
gile
  • Marseille, France
« Reply #25 on: July 18, 2015, 05:23:44 AM »
Thank you for the update, huiz.
I had not done it because I am angry with AutoCAD 2016 as it will not have solved the problem with customized osnaps.
BlackBox
« Reply #26 on: July 18, 2015, 09:41:30 AM »
... I am angry with AutoCAD 2016 as it will not have solved the problem with customized osnaps.
Despite my efforts, I know that AutoCAD 2016 implemented a new GCE (Geometric Center, aka "Gilles Chanteau Emulator" - similar to the original [CTR], but not as good with overlapping geometry :-)).
I've been a big fan of your Custom OSNAPs app since learning of it (2009 version?); not sure that I can help you, but curious to understand more about what's causing an issue with it.
Cheers
« Reply #27 on: July 18, 2015, 12:00:49 PM »
I know it killed one of the biggest timer savers I had for people at work.
huiz
« Reply #28 on: July 19, 2015, 09:17:13 AM »
Thank you too for the work you've done for the 2015 version. I only needed to define a new constant and add it to the #ifs.
Unfortunately the AutoCAD 2016 release is buggy, they also "repaired" features that were not broken. Like the Fatal error that occurs when loading a large amount of images, in the 2015 release that still worked. And the weird stuff, like the Start document that can't be closed but acts like a true document when you want the opened drawings tiled.
Well anyway we have to deal with it and keep hope for a better release next year :-)
BlackBox
« Reply #29 on: July 19, 2015, 10:02:32 AM »
You should share that here :-) :
https://beta.autodesk.com
