Author Topic: Optimizing horribly inefficient code  (Read 1952 times)
S.Langhammer
« on: September 10, 2013, 10:29:53 AM »
Hey,
the title already tells you, I'm aware, how badly inefficient the first variant is so, lough if you feel like it.
I've been away from lisp for a little while now and didn't work on my script, because I thought it was working correctly now.
WRONG.
When I try to read the entity information from a file with it, it happens that some entities within blocks are exported as if they were displaced by the insertion point of an insert (and I can't even tell which, if there are multiple inserts of the same block).
Example: a Block contains this line P1(0,1,0) P2(0,2,0)
              the block-reference would be inserted here: P3(2,5,3)
              then the exported line looks like this: P1e(2,6,3) P2e(2,7,3)
Here's the inefficient version, which seems to do the job:
  1. (defun simplify ( chkBlk / objType a b ret test)
  2.         (setq objType "")
  3.         (foreach a (Blk_ENameLstNstd chkBlk)
  4.                 (foreach b (entget a)
  5.                         (if (= (car b) 100)
  6.                                 (setq objType (cdr b))
  7.                         )
  8.                 )
  9.                 (if (= (strcase objType) "ACDBSPLINE")(progn
  10.                         (vl-catch-all-apply 'convertSpline (list a))
  11.                 ))
  12.                 (vl-catch-all-apply 'ExplodeObject (list a))
  13.         )
  14. )
  15.
  16.
  17. (defun ExplodeObject    (object
  18.        /       N_ExplodeCommandModelSpace
  19.        N_ExplodeCommandOther
  20.        N_ExplodeMethod
  21.        correctPosition
  22.        modelSpaceObject ownerObject
  23.                                                 )
  24.
  25.         (defun correctPosition (object / lastEname newEnameList newObjectList tempObject)
  26.                 (setq lastEname (entlast))
  27.                 (while (entnext lastEname)
  28.                         (setq lastEname (entnext lastEname))
  29.                 )
  30.
  31.                 (setq tempObject
  32.                         (car
  33.                                 (vlax-invoke
  34.                                         activeDocument
  35.                                         'copyobjects
  36.                                         (list object)
  37.                                         modelSpaceObject
  38.                                 )
  39.                         )
  40.                 )
  41.                 (vla-delete object)
  42.                 (while (setq lastEname (entnext lastEname))
  43.                         (setq newEnameList (cons lastEname newEnameList))
  44.                 )
  45.                 (if newEnameList
  46.                         (setq newObjectList
  47.                                 (vlax-invoke
  48.                                         activeDocument
  49.                                         'copyobjects
  50.                                         (mapcar 'vlax-ename->vla-object newEnameList)
  51.                                         ownerObject
  52.                                 )
  53.                         )
  54.                 )
  55.                 (mapcar 'entdel newEnameList)
  56.         )
  57.
  58.
  59.         (defun N_ExplodeCommandModelSpace (object / lastEname newEnameList)
  60.                 ; Store the ename of the last object in modelspace:
  61.                 (setq lastEname (entlast))
  62.                 ; Required for 'SEQEND situations':
  63.                 (while (entnext lastEname)
  64.                         (setq lastEname (entnext lastEname))
  65.                 )
  66.                 ; Use the explode command:
  67.                 (command "_.explode" (vlax-vla-object->ename object))
  68.                 ; Get the enames of all new objects in modelspace:
  69.                 (while (setq lastEname (entnext lastEname))
  70.                         (setq newEnameList (cons lastEname newEnameList))
  71.                 )
  72.                 (mapcar 'vlax-ename->vla-object newEnameList)
  73.         )
  74.
  75.                 ;; The function uses the following variables from the main function:
  76.                 ;;   docObject
  77.                 ;;   modelSpaceObject
  78.                 ;;   ownerObject
  79.         (defun N_ExplodeCommandOther (object / lastEname newEnameList newObjectList tempObject)
  80.                 ; Store the ename of the last object in modelspace:
  81.                 (setq lastEname (entlast))
  82.                 ; Required for 'SEQEND situations':
  83.                 (while (entnext lastEname)
  84.                         (setq lastEname (entnext lastEname))
  85.                 )
  86.                 ; Make a temporary copy of the object from the block definition in modelspace:
  87.                 (setq tempObject
  88.                         (car
  89.                                 (vlax-invoke
  90.                                         activeDocument
  91.                                         'copyobjects
  92.                                         (list object)
  93.                                         modelSpaceObject
  94.                                 )
  95.                         )
  96.                 )
  97.                 ; Delete the object from the block definition:
  98.                 (vla-delete object)
  99.                 ; Use the explode command:
  100.                 (command "_.explode" (vlax-vla-object->ename tempObject))
  101.                 ; Get the enames of all new objects in modelspace:
  102.                 (while (setq lastEname (entnext lastEname))
  103.                         (setq newEnameList (cons lastEname newEnameList))
  104.                 )
  105.                 ; Copy the new objects to the block definition:
  106.                 (if newEnameList
  107.                         (setq newObjectList
  108.                                 (vlax-invoke
  109.                                         activeDocument
  110.                                         'copyobjects
  111.                                         (mapcar 'vlax-ename->vla-object newEnameList)
  112.                                         ownerObject
  113.                                 )
  114.                         )
  115.                 )
  116.                 ; Delete the new entities from modelspace:
  117.                 (mapcar 'entdel newEnameList)
  118.                 ; Return the new objects in the block definition:
  119.                 newObjectList
  120.         )
  121.
  122.         (defun N_ExplodeMethod (object / newObjectList)
  123.                 (setq newObjectList (vlax-invoke object 'explode))
  124.                 (vla-delete object)
  125.                 ; Return the new objects in the block definition:
  126.                 newObjectList
  127.         )
  128.         (setq object (vlax-ename->vla-object object))
  129.         (if (vlax-method-applicable-p object 'explode)
  130.                 (N_ExplodeMethod object)
  131.                 (progn
  132.                         ; Make sure that modelspace is current:
  133.                         (setvar 'tilemode 1)
  134.                         (setq modelSpaceObject  (vla-get-modelspace activeDocument)
  135.                                   ownerObject           (vla-objectidtoobject activeDocument (vla-get-ownerid object))
  136.                         )
  137.                         (if (= ownerObject modelSpaceObject)
  138.                                 (progn
  139.                                         (if     (not(wcmatch (strcase objType) safeObjects))
  140.                                                 (N_ExplodeCommandModelSpace object)
  141.                                         )
  142.                                 )
  143.                                 (progn
  144.                                         (if     (not(wcmatch (strcase objType) safeObjects))
  145.                                                 (N_ExplodeCommandOther      object)
  146.                                                 (correctPosition                        object)
  147.                                         )
  148.                                 )
  149.
  150.                         )
  151.                 )
  152.         )
  153. )
  154. ;;;
  155.
  156.                   safeObjects "ACDBXLINE,ACDBVIEWPORT,ACDBVERTEX,ACDBTRACE,ACDBFCF,ACDBTEXT,ACDBSHAPE,ACDBRAY,ACDBPOINT,ACDBPOLYFACEMESH,ACDBOLE2FRAME,ACDBOLEFRAME,ACDBLINE,ACDBBLOCKREFERENCE,ACDBRASTERIMAGE,ACDBELLIPSE,ACDBCIRCLE,ACDBARC,ACDBFACE,ACDBATTRIBUTE,ACDBSPLINE,ACDBHATCH"
  157.
  158.         )
  159.
  160. (setq test 0)
  161.         (while  (< test 5)
  162.                 (setq chkCond nil)
  163.                 (while (setq LstBlk (tblnext "BLOCK" (not LstBlk)))
  164.                         (if     (and
  165.                                         (/=(substr(setq blkN(cdr(assoc 2 LstBlk)))1 1)"*")
  166.                                         (= T(contentCheck(Blk_ENameLstNstd blkN)))
  167.                                 )
  168.                                 (simplify blkN)
  169.                         )
  170.
  171.                 )
  172.                 (setq test (1+ test))
  173.         )
  174.
No need to tell me how badly written and horribly inefficient it is and what it behaves like in large files. But matter of fact, I have noone around to check it and help me directly.
"correctPosition" served it's purpose well. But you can imagine, how long this can take.
It was just a first quick and dirty attempt to generally find a solution for my issue so after I saw it generally worked I tryed to build it this way (explode object works about the same way, just without correctPosition):
  1.
  2. (defun simplify ( chkBlk / objType a b ret test)        ;;; löst komplexe entitäten auf, Blockname als eingangsvariable
  3.         (setq objType ""
  4.                   ret nil)
  5.         (foreach a (Blk_ENameLstNstd chkBlk)
  6.                 (foreach b (entget a)
  7.                         (if (= (car b) 100)
  8.                                 (setq objType (cdr b))
  9.                         )
  10.                 )
  11.                 (if (= (strcase objType) "ACDBSPLINE")(progn
  12.                         (vl-catch-all-apply 'convertSpline (list a))
  13.                         (setq ret T)
  14.                 ))
  15.                 (if     (not(wcmatch (strcase objType) safeObjects))(progn
  16.                         (vl-catch-all-apply 'ExplodeObject (list a))
  17.                         (setq ret T)
  18.                 ))
  19.         )
  20.         ret ;;; gibt T zurück, wenn etwas vereinfacht werden konnte, andernfalls nil
  21. )
  22. ;;;
  23. (defun correctPositionInBlock (object / lastEname newEnameList newObjectList tempObject)
  24.         ;;; ename zu objekt
  25.         (show "entität" (entget object))
  26.         (setq object (vlax-ename->vla-object object))
  27.         (show "objekt" object)
  28.         ; Make sure that modelspace is current:
  29.         (setvar 'tilemode 1)
  30.         (setq modelSpaceObject  (vla-get-modelspace activeDocument)
  31.                   ownerObject           (vla-objectidtoobject activeDocument (vla-get-ownerid object))
  32.         )
  33.
  34.         ;;; letzte entität im modelspace speichern
  35.         (setq lastEname (entlast))
  36.         (while (entnext lastEname)
  37.                 (setq lastEname (entnext lastEname))
  38.         )
  39.
  40.         ;;; temporäre kopie des objekts anlegen
  41.         (setq tempObject
  42.                 (car
  43.                         (vlax-invoke
  44.                                 activeDocument
  45.                                 'copyobjects
  46.                                 (list object)
  47.                                 modelSpaceObject
  48.                         )
  49.                 )
  50.         )
  51.         ;;; aus dem original aus dem block löschen
  52.         (vla-delete object)
  53.         ;;; liste der neuen Objekte anlegen
  54.         (while (setq lastEname (entnext lastEname))
  55.                 (show "neue entity" (entget lastEname))
  56.                 (setq newEnameList (cons lastEname newEnameList))
  57.         )
  58.         ;;; die neuen objekte zurück in den block kopieren
  59.         (if newEnameList
  60.                 (setq newObjectList
  61.                         (vlax-invoke
  62.                                 activeDocument
  63.                                 'copyobjects
  64.                                 (mapcar 'vlax-ename->vla-object newEnameList)
  65.                                 ownerObject
  66.                         )
  67.                 )
  68.         )
  69.         ;;; die temporären objekte löschen
  70.         (mapcar 'entdel newEnameList)
  71.
  72. )
  73. ;;;
  74.
  75.
  76.         (setq activeDocument (vla-get-activedocument(vlax-get-acad-object))
  77.                   safeObjects "ACDBXLINE,ACDBVIEWPORT,ACDBVERTEX,ACDBTRACE,ACDBFCF,ACDBTEXT,ACDBSHAPE,ACDBRAY,ACDBPOINT,ACDBPOLYFACEMESH,ACDBOLE2FRAME,ACDBOLEFRAME,ACDBLINE,ACDBBLOCKREFERENCE,ACDBRASTERIMAGE,ACDBELLIPSE,ACDBCIRCLE,ACDBARC,ACDBFACE,ACDBATTRIBUTE,ACDBSPLINE,ACDBHATCH"
  78.         )
  79.
  80.
  81.         (setq chkCond T
  82.                   test 0
  83.         )
  84.         (while  (and
  85.                                 (= chkCond T)
  86.                                 (< test 5)      ;;; notfall abbruch bedingung, in der regel sollte keine komplexe entität mehr als 4 ebenen haben
  87.                         )
  88.                 (setq chkCond nil)
  89.                 (while (setq LstBlk (tblnext "BLOCK" (not LstBlk)))
  90.                         (setq chkCond   (if     (and
  91.        (/=(substr(setq blkN(cdr(assoc 2 LstBlk)))1 1)"*")
  92.        (= T(contentCheck(Blk_ENameLstNstd blkN)))
  93.        )
  94.        (simplify blkN)
  95.                                                         )
  96.                                   chkCond (if chkCond chkCond nil)
  97.                         )
  98.                 )
  99.                 (setq test (1+ test))
  100.         )
  101.
  102.         (while (setq LstBlk2 (tblnext "BLOCK" (not LstBlk2)))
  103.                 (if     (/=(substr(setq blkN(cdr(assoc 2 LstBlk3)))1 1)"*")
  104.                         (foreach a (Blk_ENameLstNstd blkN)
  105.                                 (correctPositionInBlock a)
  106.                         )
  107.                 )
  108.         )
  109.
  110.
but now correcting the position doesn't work anymore. Does anyone have an idea? I'm thankfull for everything i get! (also: no need to tell me that the second version stil need refactoring. I'm aware it's still not really efficient)
roy_043
  • BricsCAD 18
Re: Optimizing horribly inefficient code
« Reply #1 on: September 11, 2013, 07:40:19 AM »
Steven, two questions:
1.
Where in your first code block do you think the coordinates are corrected? I don't see it.
2.
As you have mentioned in one of your previous posts: exploding all block is not an option. If the line in block "A" stays inside that block definition any 'correction' of coordinates does not make sense.
What should happen in this situation:
Block "A" contains a line from (0 1 0) to (0 2 0).
Block reference 1 of "A"
  Insertion point = (2 5 3)
  Scaling = (1 1 1)
Block reference 2 of "A"
  Insertion point = (11 13 39)
  Scaling = (3 -3 3)
The exported line should look like...?
S.Langhammer
« Reply #2 on: October 08, 2013, 03:06:50 AM »
First of all: I'm very sorry for the late respond. I've been to vocational college the last weeks and I have no access to the company files form my private laptop.
I should admit I'm looking at my code right now after quite a long time and I'm a bit confused myself right now.
Also I see that I accedently posted a false verison of my code. I must have made this post between two tasks. :/ Sorry about that!
The lintes 143 til 148 shouldne't be
  1.         (if     (not(wcmatch (strcase objType) safeObjects))
  2.                 (N_ExplodeCommandOther      object)
  3.                 (correctPosition                        object)
  4.         )
  5. )
  6.
but actually
  1.         (if     (wcmatch (strcase objType) safeObjects)
  2.                 (correctPosition        object)
  3.         )
  4. )
  5.
I really must have been in a rush when I posted that.
To your second question: I understand what you mean and it confuses me as well.
From the pure logical part you should be absolutly correct: there shoulden't be any displace at all. That's what I thought as well.
formating of a block:
BLOCK,"name of the block"
any entities the block might contain
End of "name of the block"
formating of a block reference: INSERT,layer,"name of the block it refairs to",Xinsertion point,Yinsertion point,Zinsertion point,Xscaling factor,Yscaling factor,Zscaling factor,rotation angle,Xextrusion direction,Yextrusion direction,Zextrusion direction(linefeed)
formating of a line: LINE,layer,Xstart point,Ystart point,Zstart point,Xend point,Yend point,Zend point,length
The export should look about like this(assuming everything is placed on layer 0):
0 //theres a list of all layers in the first line of every exported file
BLOCK,A
LINE,0,0.0000,1.0000,0.0000,0.0000,2.0000,0.0000,1.0000
End of A
INSERT,0,A,2.0000,5.0000,3.0000,1.0000,1.0000,1.0000,rotation angle,Xextrusion direction, Yextrusion direction,Zextrusion direction
INSERT,0,A,11.0000,13.0000,39.0000,3.0000,-3.0000,3.0000,rotation angle,Xextrusion direction, Yextrusion direction,Zextrusion direction
Would it be of any use if I post a kind of program flow chart how the functions of the script are supposed to work? Maybe that way I could clarify my train of thoughts and you could see errors in my algorhythm I don't see because I constantly stare at them.
You propably know how errors love to hide in the plain sight of beginners.
S.Langhammer
« Reply #3 on: October 11, 2013, 02:47:33 AM »
I'm not entirely sure but I might have found the source of the displacement.
Early in the main script I create a UCS identically to the WCS, because I don't know how to set the WCS the active coordinate system.
  1.         (vla-put-activeucs activeDocument
  2.                 (vla-add
  3.                         (vla-get-usercoordinatesystems activeDocument)
  4.                         (vlax-3d-point '(0 0 0)) ;origin
  5.                         (vlax-3d-point '(1 0 0)) ;x-axis
  6.                         (vlax-3d-point '(0 1 0)) ;y-axis
  7.                         "World"
  8.                 )
  9.         )
  10.
Then the functions to get the information from the entities look like this:
  1. (defun getInsData( ent / entName entRot entNorm LstBlk entPt  test)     ;;;Inserts
  2.         (setq entNorm   (cdr(assoc 210 ent))                    ;;; Extrusion vector
  3.                   entPt         (trans(cdr(assoc 10 ent))1 0)   ;;; Insertion point
  4.         )
  5.         ;;; in case of an anonymously or automaticly generated insert, there's a block generated
  6.         (if (=(substr(setq entName(cdr(assoc 2 ent)))1 1)"*")(progn
  7.                 ;;; breaking down non readable entities in this block
  8.                 (setq test 0)
  9.                 (while  (< test 5)      ;;; emergency stop, I haven't come across entities with more than 4 levels of complexity
  10.                         (if(= T(contentCheck(Blk_ENameLstNstd entName)))
  11.                                 (simplify blkN)
  12.                         )
  13.                         (setq test (1+ test))
  14.                 )
  15.                 (fileWrite (strcat "BLOCK," entName))
  16.                 ;;; 0 . Entitätentyp
  17.                 ;;; 1 . Blockname
  18.                 (getinfo (Blk_ENameLstNstd entName))
  19.                 (fileWrite (strcat "End of " entName))
  20.         ))
  21.         (fileWrite(strcat "INSERT,"(cdr(assoc 8 ent))"," entName ","(rtos(car entPt)2 4)","(rtos(cadr entPt)2 4)","(rtos(caddr entPt)2 4)","(rtos(cdr(assoc 41 ent))2 4)","(rtos(cdr(assoc 42 ent))2 4)","(rtos(cdr(assoc 43 ent)) 2 4)","(if(setq entRot(cdr(assoc 50 ent)))(vl-string-right-trim "r"(angtos entRot 3 4))"0")","(rtos(car entNorm)2 4)","(rtos(cadr entNorm)2 4)","(rtos(caddr entNorm)2 4)))
  22.         ;;; 0 . Entity type
  23.         ;;; 1 . Layer
  24.         ;;; 2 . Blockname
  25.         ;;; 3;4;5 . Insertion point X,Y,Z
  26.         ;;; 6;7;8 scaling X,Y,Z
  27.         ;;; 9 . Rotation
  28.         ;;; 10;11;12 . Extrusion vector
  29.         (princ)
  30. )       ;;; end getInsData
  31.
  32. ;;; and
  33.
  34. (defun getLinData( ent / entAPt entEPt) ;;; Lines
  35.         (setq entAPt    (cdr(assoc 10 ent))     ;;; Start point
  36.                   entEPt        (cdr(assoc 11 ent))     ;;; End point
  37.         )
  38.         (fileWrite(strcat "LINE,"(cdr(assoc 8 ent))","(rtos(car entAPt)2 4)","(rtos(cadr entAPt)2 4)","(rtos(caddr entAPt)2 4)","(rtos(car entEPt)2 4)","(rtos(cadr entEPt)2 4)","(rtos(caddr entEPt)2 4)","(rtos(distance entAPt entEPt)2 4)))
  39.         ;;; 0 . Entitity type
  40.         ;;; 1 . Layername
  41.         ;;; 2;3;4 . Start point
  42.         ;;; 5;6;7 . End point
  43.         ;;; 8 .  Length
  44.         (princ)
  45. )       ;;; end getLinData
  46.
Does this somehow collide in any way?
