Dynamic Data Exchange (DDE) method
(1/1)
HofCAD:
Dear Readers,
What is possible with the Dynamic Data Exchange (DDE) method
with AutoCAD(LT) and Excel?
Who is using the Dynamic Data Exchange (DDE) method?
HofCAD CSI
PS This is possible:
HofCADLT.xls
HofCADLT.xls
Change green values and click on the yellow Update, and look to the result in AutoCAD.
May be you have to change at the top of the macro's:
Const ver As Integer = 16
Const arr As String = "-ARRAY"
<Edited to remove broken links>
Maverick®:
What application would you use this for?
All the links you posted come up broken.
HofCAD:
--- Quote from: Maverick® on September 11, 2006, 11:59:06 AM ---What application would you use this for?
--- End quote ---
Sorry, I try again.
Dear Readers,
with AutoCAD(LT) and Excel(or Winword)?
It is not AutoLisp(VisualLisp) or VBA, and you can also use it in AutoCAD LT.
HofCAD CSI
PS General explanation:
Example for opening document C:\temp\hoftest.doc with a macro in Excel.
Sub Test()
ChanNum = DDEInitiate("winword", "c:\temp\hoftest.doc")
For i = 0 To 9
DDEExecute ChanNum, "Line" + Str$(i) + "{ENTER}"
Next i
DDETerminate ChanNum
See documents in:
LINK
Use in AutoCAD
See de macro's:
LINK to HofCADLT.xls
HofCADLT.xls
Change green values and click on the yellow Update, and look to the result in AutoCAD or AutoCAD LT.
LINK2
LINK3
LINK4
LINK5
- EDIT -
Repaired Links
HofCAD:
--- Quote from: HofCAD on September 11, 2006, 04:42:12 AM ---Dear Readers,
HofCAD CSI
--- End quote ---
Dear Readers,
This also possible with the Dynamic Data Exchange (DDE) method.
http://www.theswamp.org/screens/HOFDDE03.XLS
HofCAD CSI
PS Change green values and click on the yellow Update, and look to the result in AutoCAD or AutoCAD LT.
May be you have to change at the top of the macro's in Module1 (Alt+F11):
Navigation
[0] Message Index
Go to full version
