Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
global variable ussage
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: global variable ussage (Read 1432 times)
dussla
Bull Frog
on:
April 03, 2010, 05:07:35 AM »
i excuteed 2 cad app in two moniotor
i save variable value in 1 cad app
after that , i would like to use that vairable in other cad app
how can i do that ?
thank you always for answering
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: global variable ussage
Reply #1 on:
April 03, 2010, 05:24:57 AM »
Perhaps write the Variable value to a file or to the registry so you can read it from the other instance.
Logged
ElpanovEvgeniy
Water Moccasin
Moscow (Russia)
WWW
Reply #2 on:
April 03, 2010, 05:55:34 AM »
Code:
[Select]
(setenv "my var" "my value")
(getenv "my var")
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
