Uh, sure you can Michael.
Just make sure the corridor & surface are on different layers. Freeze the corridor layer (the default is C-ROAD-CORR).
However, if by "off" you mean to deselect every region in the corridor so nothing gets built, THEN you cannot have the contours, as nothing would be calculated to create them.
