Author Topic: Help, how such array  (Read 2536 times)
myloveflyer
« on: September 29, 2011, 09:23:22 PM »
The following drawings, please help us look at how to use LISP to achieve the right image!thank
Never give up !
irneb
Re: Help, how such array
« Reply #1 on: September 30, 2011, 02:26:55 AM »
Is the width of the panels always the same? Looks like 1640 on your drawing. Just guessing, but is that a standard sheet-metal size?
« Reply #2 on: September 30, 2011, 07:51:53 AM »
You could hatch using USER pattern, 90 deg and spacing 820.
Adjust the Base Point: (pick the roof peak)
;;  CAB 10.29.2007
;; Hatch Base Point Edit
(defun c:HBPEdit (/ ent elst x y bp)
  (command "._undo" "_begin")
  (if (and (setq ent (car (entsel "\nSelect hatch for new base point.")))
           (= (cdr (assoc 0 (setq elst (entget ent)))) "HATCH")
    (while (setq bp (getpoint "\nSelect new basepoint: "))
      (setq x (car bp)
            y (car (cdr bp))
      (setq elst (subst (cons 43 x) (assoc 43 elst) elst))
      (setq elst (subst (cons 44 y) (assoc 44 elst) elst))
      (entmod elst)
    (prompt "\nNot a hatch, bye.")
  (command "._undo" "_end")
Then explode the hatch.  8-)
cmwade77
« Reply #3 on: September 30, 2011, 11:52:30 AM »
The new array command in 2012 should easily be able to accomplish this as well.
« Reply #4 on: September 30, 2011, 05:31:51 PM »
How about this: (no layer support)
(defun c:test(/ p1 p2 ent)
  (if (and
    (setq p1 (getpoint "\nSpecify hatch origon."))
    (setq p2 (getpoint "\nSpecify internal point."))
       (Command "-HATCH" "_P" "_USER" 90.0 820.0 "_N" "_O" "_S" "_non" p1 "_N" "_non" p2 "")
      (if (and (setq ent (entlast)) (equal '(0 . "HATCH") (assoc 0 (entget ent))))
        (command "._explode" ent "")
myloveflyer
« Reply #5 on: October 06, 2011, 02:13:32 AM »
Irneb:
The width of the plate to artificially set, DWG is 820.
CAD:
Program failed to run.
THANKS!
This procedure is to calculate a wall plate (in addition to the window and door ) were ranked number plates, so that the processing factory
Never give up !
bchapman
« Reply #6 on: October 09, 2011, 10:16:51 PM »
Have you explored express tools -> super hatch? I've never used it but it might work for this situation.
