Author Topic: Command Line Switch Reference: "/c"  (Read 1659 times)
Peter2
« on: July 28, 2015, 03:52:06 AM »
The Command Line Switch Reference "/c" ....
Quote from: Online Help
specifies the folder location of the configuration file. If ...
That's all the same for Acad 2014 - 2016, but in 2016 it is described as "obsolete".
If it's obsolete, then why is it described?
Or what exactly is obsolete?
Peter
BricsCAD V23
huiz
  • Certified Prof C3D
Re: Command Line Switch Reference: "/c"
« Reply #1 on: July 28, 2015, 04:43:08 AM »
For software development it is a good habit to not delete obsolete functions, but mark them as obsolete or deprecated. People who use these functions can change their software or configurations without being confronted with errors.
Mostly obsolete functions will be deleted in time.
Peter2
« Reply #2 on: July 28, 2015, 07:19:42 AM »
Thanks for the explanation.
But nevertheless - not important, just curious - I would like to know if 2016 uses this switch.
BTW: The start icons uses switches which are not documented in "Command Line Switch Reference": /product and /language  :-o
Peter
BricsCAD V23
huiz
« Reply #3 on: July 28, 2015, 08:43:04 AM »
Peter2
« Reply #4 on: July 29, 2015, 03:34:08 AM »
The documentation is not always up to date :-)...
Yes - that's the bitter bill: the info is spreaded more and more (local help, online help, knowledge base, blogs, ...)  :tickedoff:
Thanks for your help, huiz.
Peter
BricsCAD V23
