Author Topic: help with coordinate table lisp  (Read 2170 times)
PM
« on: August 24, 2020, 02:16:05 AM »
Hi .I am using this code to insert a table with coordinates from a txt file in autocad. Can anyone update this code to calculate the dinstanse between the points . I attach a dwg file with the tables (i have two types .I prefrerethe right but if it is not possible and the left do the job  :smitten:) , and a txt file with the coordinates
  1. (defun c:PXY ( / *error* del des ent idx lst obj ord out rtn sel )
  2.
  3.     (defun *error* ( msg )
  4.         (if (= 'file (type des))
  5.             (close des)
  6.         )
  7.         (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
  8.             (princ (strcat "\nError: " msg))
  9.         )
  10.         (princ)
  11.     )
  12.
  13.     (setq ord '("POINT" POINT-X POINT-Y )
  14.           out  (LM:uniquefilename (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname))) ".txt")
  15.           del  ","
  16.     )
  17.     (if (setq sel (ssget '((0 . "INSERT") (66 . 1))))
  18.         (if (setq des (open out "w"))
  19.             (progn
  20.                 (repeat (setq idx (sslength sel))
  21.                     (setq ent (ssname sel (setq idx (1- idx)))
  22.                           obj (vlax-ename->vla-object ent)
  23.                     )
  24.                     (setq lst
  25.                         (append
  26.                             (mapcar '(lambda ( a b ) (cons a (rtos b)))
  27.                                '(point-x point-y point-z)
  28.                                 (trans (cdr (assoc 10 (entget ent))) ent 0)
  29.                             )
  30.                             (mapcar '(lambda ( x ) (cons (strcase (vla-get-tagstring x)) (vla-get-textstring x)))
  31.                                 (append
  32.                                     (vlax-invoke obj 'getattributes)
  33.                                     (vlax-invoke obj 'getconstantattributes)
  34.                                 )
  35.                             )
  36.                         )
  37.                     )
  38.                   ;(setq rtn (cons (vl-remove 'nil (mapcar '(lambda ( x ) (cdr (assoc x lst))) ord)) rtn))
  39. (if (and (setq pnt (assoc "POINT" lst)) (/= "" (cdr pnt)))
  40.         (setq rtn (cons (mapcar '(lambda ( x / v ) (if (and (setq v (cdr (assoc x lst))) (/= "" v)) v "0.00")) ord) rtn))
  41.     )
  42.                 )
  43.        (foreach idx (LM:alphanumsort-i (mapcar 'car rtn))
  44.        (write-line (LM:lst->str (nth idx rtn) del) des)
  45.         )
  46.                 (setq des (close des))
  47.             )
  48.             (princ (strcat "\nUnable to open file: \"" out "\" for writing."))
  49.         )
  50.     )
  51.     (princ)
  52. )
  53.
  54. ;; List to String  -  Lee Mac
  55. ;; Concatenates each string in a list, separated by a given delimiter
  56.
  57. (defun LM:lst->str ( lst del )
  58.     (if (cdr lst)
  59.         (strcat (car lst) del (LM:lst->str (cdr lst) del))
  60.         (car lst)
  61.     )
  62. )
  63.
  64. ;; Unique Filename  -  Lee Mac
  65. ;; Returns a unique filename for a given path & file extension
  66.
  67. (defun LM:uniquefilename ( pth ext / fnm tmp )
  68.     (if (findfile (setq fnm (strcat pth ext)))
  69.         (progn
  70.             (setq tmp 1)
  71.             (while (findfile (setq fnm (strcat pth "(" (itoa (setq tmp (1+ tmp))) ")" ext))))
  72.         )
  73.     )
  74.     fnm
  75. )
  76. ;; Alphanumerical Sort-i  -  Lee Mac
  77. ;; Sorts a list of strings containing a combination of alphabetical & numerical characters and returns the indices.
  78.
  79. (defun LM:alphanumsort-i ( lst )
  80.     (vl-sort-i (mapcar 'LM:splitstring lst)
  81.         (function
  82.             (lambda ( a b / x y )
  83.                 (while
  84.                     (and
  85.                         (setq x (car a))
  86.                         (setq y (car b))
  87.                         (= x y)
  88.                     )
  89.                     (setq a (cdr a)
  90.                           b (cdr b)
  91.                     )
  92.                 )
  93.                 (cond
  94.                     (   (null x) b)
  95.                     (   (null y) nil)
  96.                     (   (and (numberp x) (numberp y)) (< x y))
  97.                     (   (numberp x))
  98.                     (   (numberp y) nil)
  99.                     (   (< x y))
  100.                 )
  101.             )
  102.         )
  103.     )
  104. )
  105.
  106. ;; Split String  -  Lee Mac
  107. ;; Splits a string into a list of text and numbers
  108.
  109. (defun LM:splitstring ( str )
  110.     (
  111.         (lambda ( l )
  112.             (read
  113.                 (strcat "("
  114.                     (vl-list->string
  115.                         (apply 'append
  116.                             (mapcar
  117.                                 (function
  118.                                     (lambda ( a b c )
  119.                                         (cond
  120.                                             (   (or (= 34 b) (= 92 b))
  121.                                                 (list 32 34 92 b 34 32)
  122.                                             )
  123.                                             (   (or (< 47 b 58)
  124.                                                    ;(and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
  125.                                                     (and (= 46 b) (< 47 a 58) (< 47 c 58))
  126.                                                 )
  127.                                                 (list b)
  128.                                             )
  129.                                             (   (list 32 34 b 34 32))
  130.                                         )
  131.                                     )
  132.                                 )
  133.                                 (cons nil l) l (append (cdr l) '(( )))
  134.                             )
  135.                         )
  136.                     )
  137.                     ")"
  138.                 )
  139.             )
  140.         )
  141.         (vl-string->list str)
  142.     )
  143. )
  144.
  145.
PM
Re: help with coordinate table lisp
« Reply #1 on: August 24, 2020, 04:18:25 PM »
Is not possible ?
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: August 27, 2020, 01:46:05 AM »
Did you google pline to table should be out there already.
Right table much easier, the code provided above is maybe an over kill.
Just need a parse csv to make a list of txt file. Re Lee-mac
(Distance (list x1 y1)(list x2 y2)) use the nth function for 1-2 2-3 3-4  use (repeat (- (length lst) 1 then do last 4-1, can also do a trick copy 1st xy to list as a close.
Here is a sample make table to get you started. You need a merge cells function for last 2 lines (vla-mergecells tblobj minrow maxrow mincol maxcol)
; make table example
; By Alan H info@alanh.com.au
; 2018
(defun c:ahmaketable (/ colwidth numcolumns numrows objtable rowheight sp vgad vgao vgms)
(setq sp (vlax-3d-point (getpoint "pick a point for table")))
(Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))) ;
(setq numrows 5)
(setq numcolumns 5)
(setq rowheight 2.5)
(setq colwidth 60)
(setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth))
(vla-settext objtable 0 0 "DRAWING REGISTER"); TABLE TITLE
(vla-settext objtable 1 0 "DRAWING NUMBER")
(vla-settext objtable 1 1 "DRAWING TITLE")
(vla-settext objtable 1 2 "C")
(vla-settext objtable 1 3 "D")
(vla-settext objtable 1 4 "E")
(vla-settext objtable 2 0 "1")
(vla-settext objtable 3 0 "2")
(vla-settext objtable 4 0 "3")
(command "_zoom" "e")
[\code]
« Last Edit: August 27, 2020, 01:52:10 AM by BIGAL »
PM
« Reply #3 on: August 27, 2020, 02:21:57 AM »
Hi BIGAL. I am using block attribiutes for points in my drawings. I export the coordinates in txt file. The point numbers is not allways 1-2-3-4 , will be k1-3-6a-5-7-23-45-32 etc radom. So i use this code to convert the txt file to table.This is the code i use to export the coordinates to a file (*.crd). I dont know if is possible to convert this file to export P,X,Y,L   (point number,coord X,coord Y ,Length) and repeat the first line to the end of the file.
  2.
  5.             (close des)
  6.         )
  9.         )
  10.         (princ)
  11.     )
  12.
  14.           out  (LM:uniquefilename (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname))) ".crd")
  15.           del  ","
  16.     )
  19.             (progn
  23.                     )
  24.                     (setq lst
  25.                         (append
  29.                             )
  31.                                 (append
  34.                                 )
  35.                             )
  36.                         )
  37.                     )
  41.     )
  42.                 )
  45.         )
  47.             )
  49.         )
  50.     )
  51.     (princ)
  52. )
  53.
  56.
  58.     (if (cdr lst)
  60.         (car lst)
  61.     )
  62. )
  63.
  66.
  69.         (progn
  70.             (setq tmp 1)
  72.         )
  73.     )
  74.     fnm
  75. )
  78.
  81.         (function
  83.                 (while
  84.                     (and
  87.                         (= x y)
  88.                     )
  89.                     (setq a (cdr a)
  90.                           b (cdr b)
  91.                     )
  92.                 )
  93.                 (cond
  94.                     (   (null x) b)
  95.                     (   (null y) nil)
  97.                     (   (numberp x))
  99.                     (   (< x y))
  100.                 )
  101.             )
  102.         )
  103.     )
  104. )
  105.
  108.
  110.     (
  111.         (lambda ( l )
  112.             (read
  113.                 (strcat "("
  115.                         (apply 'append
  116.                             (mapcar
  117.                                 (function
  119.                                         (cond
  122.                                             )
  126.                                                 )
  127.                                                 (list b)
  128.                                             )
  130.                                         )
  131.                                     )
  132.                                 )
  134.                             )
  135.                         )
  136.                     )
  137.                     ")"
  138.                 )
  139.             )
  140.         )
  142.     )
  143. )
  144.
  145.
d2010
« Reply #4 on: August 27, 2020, 07:07:27 AM »
You do not need Extract 'Coordinates to CSV file. Your programe can extract iCadastral-Infromations directly from the "CL_aclayer-dorinmur-sanpaul.dwg"
You execute the "pp_tabelpol_jsdup35.lsp" with command XTB[enter]
PM
« Reply #5 on: August 27, 2020, 09:37:59 AM »
i can not understant .What program ?
d2010
« Reply #6 on: August 27, 2020, 03:23:59 PM »
You try the programe "pp_tabelpol_jsdup35.lsp" with xtb[enter]
PM
« Reply #7 on: August 27, 2020, 03:26:17 PM »
i dont have any pp_tabelpol_jsdup35.lsp and i dont know what is  xtb
BIGAL
« Reply #8 on: August 27, 2020, 07:20:04 PM »
Download the zip file.
PM
« Reply #9 on: August 28, 2020, 12:41:43 AM »
I see now the zip file .was on top of the image and i see only the gif file :)
