Author Topic: how to protect my lisp file  (Read 3694 times)
flowera
« on: July 03, 2006, 05:08:26 AM »
This is my first post of this forum.
I have done AutoLISP program,How to protect my LISP program?
jonesy
  • SuperMod
Re: how to protect my lisp file
« Reply #1 on: July 03, 2006, 05:24:47 AM »
Hi Flowera
Welcome to theswamp.
Unfortunately I dont know how to program in lisp, but I'm sure one of our programming experts will be along shortly to help you
Tracey
« Reply #2 on: July 03, 2006, 05:42:28 AM »
Have a quick look here, for starters ..
flowera
« Reply #3 on: July 03, 2006, 06:01:23 AM »
I couldn,t understand for Autocad Help
« Reply #4 on: July 03, 2006, 06:29:16 AM »
What DO you understand ?  ... tell what you know.
What don't you understand ?
jonesy
  • SuperMod
« Reply #5 on: July 03, 2006, 06:57:53 AM »
Kerry, I have a feeling that flowera doesnt speak English too well (sorry if this is not the case)
Maybe they dont understand the language in the image file? (just a thought)
Andrea
« Reply #6 on: July 03, 2006, 09:07:21 AM »
(defun c:LISP2FAS ( / str1 num1 str2)
  (setq str1 (getfiled "LISP file..." "" "LSP" 2))
  (setq num1 (strlen str1))
  (setq str2 (strcat (substr str1 1 (- num1 4)) ".fas"))
  (vlisp-compile 'st str1 str2)
Keep smile...
flowera
« Reply #7 on: July 03, 2006, 10:46:24 AM »
Thank u.
I have protected my lisp file.
Hi friends I understand ur english very well.
