I would thank you for sharing the program, but why not simply use an AutoCAD Table object in which the text alignment can be easily set for each cell?
Quote from: Lee Mac on August 25, 2012, 07:02:59 AMI would thank you for sharing the program, but why not simply use an AutoCAD Table object in which the text alignment can be easily set for each cell?Dear sir,it's use manually draw table
Quote from: Sam on August 25, 2012, 07:32:48 AMQuote from: Lee Mac on August 25, 2012, 07:02:59 AMI would thank you for sharing the program, but why not simply use an AutoCAD Table object in which the text alignment can be easily set for each cell?Dear sir,it's use manually draw table nice. but why vlx ?k.
