Author Topic: How do I explode a block using a script?  (Read 8443 times)
Luke
Re: How do I explode a block using a script?
« Reply #15 on: January 10, 2008, 01:14:25 PM »
Yes, that seems to do it also.  But so now here's my stupid question...
what is the command to ECS in a script.
I tried ^C^C
I tried ESC
I tried CANCEL
David Hall
  • Automatic Duh Generator
« Reply #16 on: January 10, 2008, 01:14:32 PM »
yes, but that would define his dimstyles correct?  Hes inserting a blank dwg that has the styles defined
David Hall
« Reply #17 on: January 10, 2008, 01:15:01 PM »
(command)  its a lisp thing
« Reply #18 on: January 10, 2008, 01:30:29 PM »
I tried ^C^C
I tried ESC
I tried CANCEL
Commander,
Typically one does not use escape in a script.  From Help:
Each line of the script file contains a command. Each blank space in a script file is significant because SPACEBAR is accepted as a command or data field terminator. You must be very familiar with the sequence of prompts to provide an appropriate sequence of responses in the script file.
NoteKeep in mind that prompts and command names may change in future releases, so you may need to revise your scripts when you upgrade to a later version of this program. For similar reasons, avoid the use of abbreviations; future command additions might create ambiguities.
A script can execute any command at the command prompt except a command that displays a dialog box. In most cases, a command that displays a dialog box has an alternative version of the command that displays command prompts instead of a dialog box.
Script files can contain comments. Any line that begins with a semicolon (;) is considered a comment, and it is ignored while the script file is being processed. The last line of the file must be blank.
All references to long file names that contain embedded spaces must be enclosed in double quotes. ...A script is treated as a group, a unit of commands, reversible by a single U command. However, each command in the script causes an entry in the undo log, which can slow script processing. If you like, you can use UNDO Control None to turn off the undo feature before running the script, or you can write it at the beginning of the script itself. Remember to turn it back on (UNDO Control All) when the script is finished.
Instead one would 'enter' through until the end of the desired command or action had been executed.  Sort of like the first rule of writing a script; is to know all of the command actions, and prompts as well as the objects you want to action on prior to writing the script.
Luke
« Reply #19 on: January 10, 2008, 01:42:02 PM »
(command) to cancel does work.  However, in my case this is just a small portion withing a huge script so cancel stops the script.  So for me I need to do it one of these 2 ways...
If I use the * per mjfarrell  code needs to be...
Code:
-insert
*LCC_DIMSTYLES.dwg
0,0,0
1
0
If I use the (command "._explode" (entlast)) per ronjonp code needs to be...
Code:
-insert
LCC_DIMSTYLES.dwg
0,0,0
1
1
0
ELOQUINTET
« Reply #20 on: January 11, 2008, 07:45:19 PM »
i have asked this question on several occasions here for similar reasons. we will get architectural drawings sent to us and the xrefs will be bound as inserts but i need to prepare the drawings for our use. the first thing i need to do is explode the blocks then go through the rest of the processes. i haven't been able to figure out how to cancel out of the exploding of these blocks but continue with the rest after. you say (command) does cancel out does resume work for resuming in this instance. i've read about that but am not able to test it right now?
« Reply #21 on: January 11, 2008, 09:05:52 PM »
Dan,
What exactly do you do to "prepare" these files?
Ron
ELOQUINTET
« Reply #22 on: January 14, 2008, 08:53:30 AM »
it depends on the files ron but mostly we explode any bound xrefs then manipulate  layer color and visibility and purge out unwanted stuff. this and not being able to shrink the size of the missing xref path are my 2 main problems. When we bring these into our template we want to leave behind as much unwanted garbage as we can.
