Author Topic: Updating a block routine, ...  (Read 4968 times)
Hangman
« on: May 08, 2007, 01:41:41 PM »
Hey guys,
Can someone please help me with a routine.
This is what I have, but I'm stuck between a rock and hard spot at the moment, I don't have the time to add a little some'thn some'thn to it.
(defun c:TY (/ oldecho oldos Sel EntData Txt)
  (defun $error (msg /)
    (if (or (= msg "Function cancelled")
            (/= msg "quit / exit abort")
        (princ (strcat "Error: " msg))
    (command ".undo" "e" "undo" "")
    (command ".redraw")
    (setvar "cmdecho" oldecho)
    (setq *error* old_err)
  );end error
  (setq old_err *error*
        *error* $error
        oldecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (and
    (setq Sel (nentsel "\n Select text to copy: "))
    (setq EntData (entget (car Sel)))
    (setq Txt (cdr (assoc 1 EntData)))
    (setq Sel (nentsel "\n Select attribute to replace: "))
    (entmod (subst (cons 1 Txt) (assoc 1 EntData) EntData))
    (entupd (car Sel)))
Could one of you guru's please create a piece of code for me ??
I have a block with an attribute text.  This routine currently gets the info from the attribute text and adds it to another piece of attribute text.
What I need to add is something that will also get the text properties of that attribute text to add to the other.
EXAMPLE:  I have a block (A) with a line of text  "SEE ARCH" with a width of 0.5.
The block I am updating (block 'B') has a line of text "----" with a width of 0.75.
I need to be able to select the text of block 'A' and select the text of block 'B' and have the text of block 'B' be identical to that of block 'A'.
Thank you in Advance for your expertise.
« Last Edit: May 08, 2007, 02:25:20 PM by Hangman »
Hangman  8)
Maverick®
Re: Out'a time ...
« Reply #1 on: May 08, 2007, 01:59:23 PM »
  Hiya Hangman.  How's about changing the thread name to something a little more descriptive?
  "Copying block text" or something like that.
Guest
Re: Out'a time ...
« Reply #2 on: May 08, 2007, 02:03:07 PM »
If Se7en saw this he'd be rolling over in his grav....What?   He's what?  You mean he's not.... Oh.   Oops!
Re: Out'a time ...
« Reply #3 on: May 08, 2007, 02:22:53 PM »
Nice subject title Hangman!
(Your quick Mav!)
Hangman
Re: Out'a time ...
« Reply #4 on: May 08, 2007, 02:24:20 PM »
Good point, ... I'm in a rush, ...  always in a rush.  :(
Sorry, ...  Sorry, ...  won't happen again.
Hangman  8)
Re: Out'a time ...
« Reply #5 on: May 08, 2007, 02:27:41 PM »
What properties to do you want to match?  Color? Layer? Lineweight? Width? Height?
Here is a real simple way to do it, and you can add more properties as you like.
(and
 (setq Sel (nentsel "\n Select text/attribute to match properties from: "))
 (setq FromObj (vlax-ename->vla-object (car Sel)))
 (setq Sel (nentsel "\n Select text/attribute to match properties to: "))
 (setq ToObj (vlax-ename->vla-object (car Sel)))
 (mapcar
  '(lambda (x)
   (vlax-put ToObj x (vlax-get FromObj x))
  '("Height" "Color" "Layer" "ScaleFactor")
Hangman
Re: Updating a block routine, ...
« Reply #6 on: May 08, 2007, 02:40:03 PM »
Good question, sorry I didn't post this earlier.  I'm just looking for width at the moment.
I am assuming, at some later date when I have a few seconds, I can take and expand on it.
Hangman  8)
deegeecees
« Reply #7 on: May 08, 2007, 02:44:28 PM »
Width = DXF code 41
deegeecees
« Reply #8 on: May 08, 2007, 02:49:39 PM »
Haven't tested but it should work:
    (command ".redraw")
  );end error
        *error* $error
  (and
    (setq wid (cdr (assoc 41 EntData)))
    (entmod (subst (cons 41 wid) (assoc 41 EntData) EntData))
    (entupd (car Sel)))
Added:
« Reply #9 on: May 08, 2007, 02:53:16 PM »
In my code, width = SacleFactor.  So you can erase the others and just leave that one in.
Hangman
« Reply #10 on: May 08, 2007, 04:21:37 PM »
( ...  taking a breath, ...  reading ...  reading ...  breathing, ...  OK, times up !! )
Thanks guys, I appreciate the help.
Tried the code posted from both Tim & DGC, but alas, ...
It seems to incorporate the width factor, but it won't do the text now.
It's as if the one (the Wid) is over-riding the other (Txt).
Hangman  8)
« Reply #11 on: May 08, 2007, 04:32:31 PM »
To copy the text also, have the list of properties look like
'("ScaleFactor" "TextString")
Hangman
« Reply #12 on: May 08, 2007, 05:01:20 PM »
No, it does put the program back to copying the text, but it doesn't do both the text and the width.
Hmmm, ...  it's a good thing I came to you guys, I wouldn't of figured this out.  I've tried a couple different things, ended up with two different programs.
I appreciate your help.
Hangman  8)
« Reply #13 on: May 08, 2007, 05:22:07 PM »
This works with my testing here.
(and
 (mapcar
  '(lambda (x)
terrycadd
Text and Attribute Match routine
« Reply #14 on: May 09, 2007, 11:21:16 AM »
It sounds like you're needing something like the following.
; c:TAM - Text and Attribute Match
(defun c:TAM (/ EntList@ EntName^ EntPick@ EntType$ Loop Match$ Next$ Text$)
  (princ "\nText and Attribute Match")
  (if (setq EntPick@ (nentsel "\nSelect text or attribute text to match: "))
      (setq EntName^ (car EntPick@)
            EntList@ (entget EntName^)
            Match$ (if (assoc 1 EntList@) (cdr (assoc 1 EntList@)))
            Loop (if Match$ t nil)
            Next$ ""
      );setq
      (while Loop
        (if (setq EntPick@ (nentsel (strcat "\nSelect " Next$ "text or attribute text to replace with \"" Match$ "\": ")))
                Text$ (if (assoc 1 EntList@) (cdr (assoc 1 EntList@)))
          );setq
        );if
        (if Text$
            (setq EntList@ (entmod (subst (cons 1 Match$) (assoc 1 EntList@) EntList@))
                  EntType$ (cdr (assoc 0 EntList@))
            );setq
            (entupd EntName^)
            (if (or (= EntType$ "MTEXT")(= EntType$ "TEXT"))
              (command "REGEN")
            );if
          );progn
            (princ "\nNo text or attribute text selected to replace.")
            (setq Loop nil)
          );progn
        );if
        (setq Next$ (if (= Next$ "") "next " ""))
      );while
    );progn
    (princ "\nNo text or attribute text selected to match.")
  );if
);defun c:TAM
This loop version doesn't modify the width, only the text.
« Last Edit: May 09, 2007, 03:34:11 PM by Terry Cadd »
