Author Topic: text rejustification on mirror...  (Read 1930 times)
Andrea
« on: December 07, 2006, 10:22:00 AM »
Good morning all..
I have this little basic LISP who redefine text justification when mirror is done.
but I don't like it.....
and would be glad to see if any of you have a routine similar...or something else doing this.
(see picture)
(defun MIRR2 ()
(initget "Gd Dg")
  (setq opt1 (getkword "Mirroir de GD ou DG <Droite Gauche>: "))
  (if (eq opt1 nil)(setq opt1 "Dg"))
(setq mobjets (ssget))
(setq mob (sslength mobjets))
(setq val1 (- mob 1))
(repeat mob
 (setq a1 (entget (ssname mobjets val1)));;détail de l'entité
 (setq a2 (cdr (assoc 0 a1)))
(if (eq a2 "TEXT")
 (setq spt_ins (cdr (assoc 10 a1))) ;;Insertion point
(if (eq opt1 "Dg") (command "_justifytext" (cdr (assoc -1 a1)) "" "_R"))
(if (eq opt1 "Gd") (command "_justifytext" (cdr (assoc -1 a1)) "" "_L"))
(setq val1 (- val1 1))
(setq val1 (- val1 1)))
(setq Mp1 (getpoint "Spécifiez le premier point de la ligne de symétrie:")
      Mp2 (getpoint Mp1 "Spécifiez le deuxième point de la ligne de symétrie:"))
(command "_mirror" mobjets "" Mp1 Mp2 "_Y")
Keep smile...
sinc
Re: text rejustification on mirror...
« Reply #1 on: December 07, 2006, 05:45:31 PM »
Good morning all..
Is there some reason you aren't just using a standard QLeader?
