Author Topic: MText and Leaders  (Read 1364 times)
jrr114
MText and Leaders
« on: June 20, 2023, 03:01:53 PM »
Is there a lisp that disassociates MText from quick leaders?  I know that there is a command in express tools.  Having a lisp or button would be easier.
BIGAL
  • 40 + years of using Autocad
Re: MText and Leaders
« Reply #1 on: June 20, 2023, 07:41:06 PM »
Something like this
(setq txt (cdr (assoc 1 (entget (cdr (assoc 340 (entget (car (entsel "\nPick leader ")))))))))
jrr114
« Reply #2 on: June 22, 2023, 03:47:04 PM »
BigAl,
Please excuse my lack of knowledge.  What would the command be for this?
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #3 on: June 22, 2023, 04:55:51 PM »
BigAl,
you'd need to wrap that statement in a command.
Something like :
  1. (defun c:DOIT ()
  2.   (setq txt
  3.          (cdr
  4.            (assoc
  5.              1
  6.              (entget
  7.                (cdr (assoc
  8.                       340
  9.                       (entget (car (entsel "\nPick leader ")))
  10.                     )
  11.                )
  12.              )
  13.            )
  14.          )
  15.   )
  16. )
  17.
  18.
Note: I assume the statement serves the purpose you require.
« Last Edit: June 22, 2023, 04:59:16 PM by kdub_nz »
Called Kerry in my other life
I live at UTC + 13.00
BIGAL
« Reply #4 on: June 22, 2023, 07:37:24 PM »
Thanks Kdub_nz
Another must pick the text
(defun c:doit ( / )
(setq txt (cdr
  (assoc 1
    (entget
      (car (nentsel "\nPick the text ")
(setq txt (vlax-get (vlax-ename->vla-object
  (car  (nentsel "Pick text ")
    'TEXTstring)
« Last Edit: June 22, 2023, 07:44:42 PM by BIGAL »
Tharwat
  • Hypersensitive
« Reply #5 on: June 23, 2023, 06:01:02 AM »
Give this a go and let me know.
  1. (defun c:Test (/ int ent sel dxf get )
  2.   ;;----------------------------------------------------;;
  3.   ;;    Author : Tharwat Al Choufi                      ;;
  4.   ;; website: https://autolispprograms.wordpress.com    ;;
  5.   ;;----------------------------------------------------;;
  6.   (and (princ "\nSelect Mtext to disassociate from its related leader : ")
  7.        (setq int -1 sel (ssget "_:L" '((0 . "MTEXT"))))
  8.        (while (setq int (1+ int) ent (ssname sel int))
  9.          (and (assoc 102 (setq get (entget ent)))
  10.               (or (setq dxf nil)
  11.                   (mapcar '(lambda (itm) (or (= (car itm) 102) (setq dxf (cons itm dxf)))) get)
  12.                   )
  13.               (entmake (reverse dxf))
  14.               (entdel ent)
  15.               )
  16.          )
  17.        )
  18.   (princ)
  19.   )
jrr114
« Reply #6 on: June 26, 2023, 01:35:22 PM »
I am able to get Tharwat's "test" LISP to work but not the other one.  I'm sure that it is user error on my part.  I appreciate all that you guys are doing to help me.
I'm guessing that I can changes the command name from test to LdrDis?
dwaschnia
  • Mosquito
« Reply #7 on: June 27, 2023, 03:15:10 AM »
What do you mean with "disassociate the mtext"?
Do you want only the mtext to remain from selected mleaders?
If so, try this:
  1. (defun c:foo ( / le ss e ss2 )
  2.   (setq le (entlast))
  3.   (if (setq ss (ssget "_:L" '((0 . "MULTILEADER"))))
  4.     (progn
  5.       (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
  6.         (command "._explode" x)
  7.       )
  8.       (setq e (entnext le))
  9.       (setq ss2 (ssadd))
  10.       (while e
  11.         (setq ss2 (ssadd e ss2))
  12.         (setq e (entnext e))
  13.       )
  14.       (foreach x (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss2))))
  15.         (if (/= (vla-get-objectname x) "AcDbMText")
  16.           (vla-delete x)
  17.         )
  18.       )
  19.     )
  20.   )
  21. )
  22.
Tharwat
  • Hypersensitive
« Reply #8 on: June 27, 2023, 07:10:51 AM »
If so, try this:
The OP is referring to Qleader and NOT Multileader, and they want to delink the connection between Mtext and Leader objects so the text won't follow the leader if leader object moved / relocated after all and that what it's called disassociate.
dwaschnia
  • Mosquito
« Reply #9 on: June 27, 2023, 08:01:49 AM »
If so, try this:
Oh, I see. Never heard of qleaders before. The disassociating part seems to happen automatically for me, when I make one (bricscad).
