Author Topic: AutoCAD Fatal Errors  (Read 2842 times)
ChrisCarlson
« on: July 31, 2014, 08:45:05 AM »
Is there a way for regular Joe's like me to dig into AutoCAD fatal errors to see what command, process or murmured phrase crashed AutoCAD?
Rob...
Re: AutoCAD Fatal Errors
« Reply #1 on: July 31, 2014, 08:47:11 AM »
Sometimes, a quick search of the error numbers will reveal the cause.
CAD Tech
« Reply #2 on: July 31, 2014, 08:54:58 AM »
read the dump file in your temp folder
huiz
  • Certified Prof C3D
« Reply #3 on: July 31, 2014, 09:52:57 AM »
If Autodesk knew them all, they would probably have served better messages instead of a number.
Wouldn't they?
tedg
« Reply #4 on: July 31, 2014, 10:20:27 AM »
Wouldn't they?
That's crazy talk, Autodesk actually fixing problems before adding new features on new releases?
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
dgorsman
« Reply #5 on: July 31, 2014, 01:18:48 PM »
Wouldn't they?
Never mind that a planned future upgrade would render the fix irrelevant.  They should just go ahead and waste project budgets to tick-the-box.   :angel:
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
JONTHEPOPE
« Reply #6 on: August 09, 2014, 01:13:49 PM »
I spend more time crashing AutoCAD then working in it.
CaddmannQ
« Reply #7 on: August 12, 2014, 01:34:43 PM »
Hey I just loaded BDSP 2015 on all our machines, and so far not a single crash or fatal error!
It's so stable it's actually scary.  :-o
« Reply #8 on: August 12, 2014, 03:41:02 PM »
Is it not a sad state of affairs, that what should be normal for such touted software, has come to be viewed as abnormal?
I would hope that Autodesk doesn't steal a page from the Cellular Industry; "Can you Hear me Now?" campaign.
Imagine the marketing opportunity:
"Are you crashing now?"
CaddmannQ
« Reply #9 on: August 12, 2014, 05:13:46 PM »
It's sad the way we have come to regard the entire business, and from both sides.
