Author Topic: Routine to remove all association of dimensions  (Read 2686 times)
TJAM51
« on: May 16, 2006, 08:43:54 AM »
I am using 2007. I am seeking a routine that would allow me to either pick or it globally choose all dimensions within a drawing to remove the association....thanks
CADaver
Re: Routine to remove all association of dimensions
« Reply #1 on: May 16, 2006, 09:17:46 AM »
dunno 'bout 2007, but in 2002 theres a command:
dimdisassociate
Select dimensions to disassociate: Select one or more dimensions and then press ENTER
DIMDISASSOCIATE filters the selection set to include only associative dimensions that are not on locked layers, and that are not in a different space than the current space (for example, if model space is active, associative dimensions in paper space are excluded). DIMDISASSOCIATE then disassociates these dimensions and reports the number of dimensions that are filtered out and the number that are disassociated.
TJAM51
« Reply #2 on: May 16, 2006, 09:45:03 AM »
Thanks.....I really appreciate it.
hudster
« Reply #3 on: May 17, 2006, 03:26:24 AM »
the question remains though, why would you want to do this?
CADaver
« Reply #4 on: May 17, 2006, 07:46:24 AM »
I was hoping somebody besides me would ask.
