Author Topic: how to get the insertion scale  (Read 2694 times)
PanHasan
« on: September 11, 2009, 06:34:56 PM »
Hi
i have no idea how to dig it. Normally it is located in autocad drawing utilities and then units but how to get there from vb .net has anybody a diagram or something how should i find that kind of things
Re: how to get the insertion scale
« Reply #1 on: September 11, 2009, 07:08:14 PM »
Do you mean the Application SystemVariable "DIMSCALE" ?
« Last Edit: September 11, 2009, 07:15:17 PM by Kerry Brown »
« Reply #2 on: September 11, 2009, 07:22:20 PM »
Perhaps ...
Autodesk.AutoCAD.DatabaseServices.DataBase.get_Dimscale();
or
Autodesk.AutoCAD.DatabaseServices.Dimension.get_Dimscale();
or
Autodesk.AutoCAD.DatabaseServices.BlockReference.get_ScaleFactors();
« Last Edit: September 11, 2009, 07:49:10 PM by Kerry Brown »
PanHasan
« Reply #3 on: September 12, 2009, 04:22:20 AM »
No
I've meant insertion units and i found it here so its OK
Application.DocumentManager.MdiActiveDocument.Database.Insunits
and its returns if the insertion scale are a millimeters or centimeters or something else
but i wonder why i don't have non of them (get_Dimscale(),get_ScaleFactors())
i can get that far
SEANT
« Reply #4 on: September 12, 2009, 06:29:03 AM »
Indeed.
Kerry, are those custom extension methods.  That seems sensible enough for get_ScaleFactors() – to “blackbox” the Scale3d object.   A requirement for extension method get_Dimscale is not so obvious.
Sean Tessier
AutoCAD 2016 Mechanical
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: September 12, 2009, 11:57:41 AM »
I believe those are just properties of the objects
« Reply #6 on: September 12, 2009, 06:24:43 PM »
Yes, DimScale and ScaleFactors are public propertys, with get/set accessors  ;
