I do not believe that setting ones point style to FLATTEN the elevations has any impact on feature lines or breaklines.
Let me test and report back post haste.
Hi Mike F
I did find out what happens. If you turn a point style to flatten it does affect Feature Lines.
If flattened when you create a feature line it does the first point to surface if you have one defined.
What is next is what is different. The second pt will not pick up the surface elev by default (with a second step
you can choose (SU) for surface and then it will work. So it does work but with a extra step to make it happen.
If you have the point style to use elevation it allows you to choose the surface by default on acquiring the second pt
and to the end of the feature line.
MJP
Mike that is the way that particular tool always works, flatten points or not.
From the command line of a file using a DEM surface...
Command:
Specify start point:
Specify elevation or [Surface] <0.000>: s
Surface: DEM
Surface elevation or [Select surface] <59.376>:
Specify the next point or [Arc]:
Distance 138.556', Grade 0.00, Slope Horizontal, Elevation 59.376'
Specify grade or [SLope/Elevation/Difference/SUrface/Transition] <0.00>:
notice it prompts for the surface at each endpoint?
In my class I would teach you to use a different technique that is faster and more efficient.
Draw the polyline with your node snap on,
or use point number range; from lines and curves menu...
Now here's the 'trick'
convert this object into a feature line
USE the option to assign elevations to it....
DO NOT get the intermediate breaks...
Use the surface, and all points along the feature line are now set at the point (surface) elevation.
It's faster... really...
