Author Topic: Choosing routine  (Read 5209 times)
DEVITG
Choosing routine
« on: February 23, 2004, 05:32:30 PM »
Please help with this routine.
I'm trying to choose one of two defun (CCW) or (CW) according to the L or R
(DEFUN ORIENT ()
  (INITGET 1 "L R")
  (SETQ MODE
(GETKWORD
  "\nWHICH WAY YOU WANT TO DRAW THE ELLBOWS  ? LEFT or RIGTH "
) ;_end getkword
  ) ;_end setq code
  (if (= MODE (or "l" "L"))
    (CcW)
    (cw)
) ;_end orient
As  MODE only could be "l" "L" or "r" "R"
The if should route to CCW if MODE= "l" or "L"
or to CW if MODE ="r" or "R"
But it  allways route me to CW
  What I'm doing wrong??? :oops:  :cry:  :roll:
Choosing routine
« Reply #1 on: February 23, 2004, 05:41:13 PM »
You dont have to worry about upper/lower case because of the
initget. And you don't need to check 'mode' because an escape
is the only way to exit and that would stop the whole routine.
Instead of an 'if' use a 'cond' to test for either 'L' or 'R'
(cond ((= mode "L")(Ccw))
 ((= mode "R")(cw))
Choosing routine
« Reply #2 on: February 23, 2004, 05:50:49 PM »
As they say, "the proof is in the pudding"
Command: (orient)
WHICH WAY YOU WANT TO DRAW THE ELLBOWS  ? LEFT or RIGTH r
R
Command: (orient)
WHICH WAY YOU WANT TO DRAW THE ELLBOWS  ? LEFT or RIGTH l
L
Command: (orient)
WHICH WAY YOU WANT TO DRAW THE ELLBOWS  ? LEFT or RIGTH <enter>
Invalid option keyword.
WHICH WAY YOU WANT TO DRAW THE ELLBOWS  ? LEFT or RIGTH 4
WHICH WAY YOU WANT TO DRAW THE ELLBOWS  ? LEFT or RIGTH -1
WHICH WAY YOU WANT TO DRAW THE ELLBOWS  ? LEFT or RIGTH  <escape>*Cancel*
; error: Function cancelled
notice when I entered a lowercase 'r' it returned an uppercase 'R' :D
DEVITG
I got it
« Reply #3 on: February 23, 2004, 07:23:58 PM »
After a lot of trial and error , and half an hour at the TV seing The Simpson, I got the way to do it.
Despite the initget "L R" only allow to type an L or R no matter if capital or not, the MODE is setq to R , r  L , l .
Just to tes I did it
Command: !MODE
"L"
Command: (= MODE "l")
nil
So I solved it as follow
(DEFUN ORIENT (/ MODE)
  (INITGET 1 "L R")
  (SETQ MODE
(GETKWORD
) ;_end getkword
  ) ;_end setq MODE
  (COND
    ((= MODE "l") (CCW))
    ((= MODE "L") (CCW))
    ((= MODE "R") (CW))
    ((= MODE "r") (CW))
  ) ;_END COND
) ;_END ORIENT
Choosing routine
« Reply #4 on: February 23, 2004, 08:07:21 PM »
DEVITG
When you use (INITGET 1 "L" "R") the return value R or L is in uppercase.
No need to test for lower case.
See the test run Mark printed. If you enter r then Mode will be R.
This is all you need. Enter r and see.
  (INITGET 1 "L R")
  (SETQ   MODE
    (GETKWORD
    ) ;_end getkword
  ) ;_end setq MODE
   (COND
    ((= MODE "R") (CW))
  ) ;_END COND
) ;_END ORIENT
DEVITG
Choosing routine
« Reply #5 on: February 23, 2004, 09:51:02 PM »
Ok I will see it tomorrow.
hendie
Choosing routine
« Reply #6 on: February 24, 2004, 03:19:58 AM »
*ahem* ELLBOW only has 1 "L" (ELBOW)
Choosing routine
« Reply #7 on: February 24, 2004, 06:18:49 AM »
:yikes:
hudster
Choosing routine
« Reply #8 on: February 24, 2004, 07:17:03 AM »
Seeing as how we are on spelling.
rigth is actually spelt RIGHT. :lol:
SMadsen
Choosing routine
« Reply #9 on: February 24, 2004, 08:47:10 AM »
Here's one using the "RRB Default Method":
(defun orient ()
  (initget "Left Right")
  (cond ((= "Left" (cond ((getkword
                   "\nElbow direction [Left/Right] <Right>: "))
                   ("Right")))
         (ccw))
        ((cw))
DEVITG
I WAS ON A MISSTAKE:oops: :oops:
« Reply #10 on: February 24, 2004, 12:43:04 PM »
Cab, you are rigth, I learned other more LISP topic today.
Keith , english is my second language , so often I make errors.
SMadsen.
Would you please explain how it  work? , there are  nested COND I do not see clear.
It work well , but I do not know why :oops:
SMadsen
Choosing routine
« Reply #11 on: February 24, 2004, 01:26:40 PM »
DEVITG, it'll be my pleasure.
As you might know, COND works like a select-case function:
(cond  ((is this true?) (then do this))
       ((ok, so is this true?) (then do this))
       ((hmm, is this true then?) (then do this))
(setq a 7)
(cond ((= a 9)(princ "No way this is printed"))
      ((= 0 (rem a 2))
       (princ "Nope, the remainder of 7/2 is not 0")
       (princ "This will not be printed, either")
      ((= a (* 2 3.5))
       (princ "Yeah, this is true! Print me!")
Sorry about the silly example, but have a look at the conditions and forget everything else. COND runs down the "list" of conditions and evaluates each one. When - or if - it finds a condition that is not nil, it will execute not only the condition but also any following statements and RETURN the value of the last statement.
Hence, the silly example above will print "Yeah, this is true! Print me!" to the screen.
Now, remove all following statements, leaving only the conditions:
(setq a 7)
(cond ((= a 9))
      ((= 0 (rem a 2)))
      ((= a (* 2 3.5)))
What will this return? Again, it runs down all conditions and evaluates them. When - or if - it finds a condition that is not nil, it executes not only the condition but .. ummm, wait, there are no following statements! So, it will simply return the value of the condition - which in this case is T.
Let's take a look at the innermost COND (of course, we'll include the INITGET, without which the GETKWORD makes no sense):
(cond ((getkword "\nElbow direction [Left/Right] <Right>: "))
      ("Right")
Notice that there are only conditions within the COND. But it doesn't matter because we just learned that COND will return the value of the first non-nil condition when there are no statements following the condition.
So, GETKWORD will switch to AutoCAD and await an answer. We can expect three different answers to arrive:
1. the user hits Enter and GETKWORD returns nil
2. the user types "Left" (or "L" or "Le" ...) and GETKWORD returns "Left"
3. the user types "Right" (or "R" ...) and GETKWORD returns "Right"
How will COND react to each of these answers? Let's take them in reverse order:
3. Because GETKWORD is the condition and it returns "Right", COND will see this as a non-nil value and return the result of the condition - which is "Right"
2. The same as 3., only that GETKWORD returns "Left".
1. If the user hits Enter and causes GETKWORD to return nil, COND will jump to the next condition which simply is the string "Right". A string is not a non-nil value and will therefore be returned by COND.
Because "Right" is offered as the default answer, it shall also be returned if the user hits Enter. This is accomplished by inserting "Right" as a condition.
The outermost COND simply says: if the innermost COND returns "Left" then do CCW, otherwise do CW. The latter is triggered by "Right", which is triggered by the user typing "R" or by hitting Enter.
The outermost COND could easily be written as an IF if it makes more sense:
(if (= "Left"
             ("Right")
  (ccw)
  (cw)
DEVITG
nested cond
« Reply #12 on: February 24, 2004, 02:16:34 PM »
SMadsen, thank for your explanation , I shall chew it a lot  , and see what I get.
Thanks againg
