Author Topic: Select Multiple Files  (Read 7723 times)
Guest
« on: July 18, 2007, 09:52:55 AM »
Is there a VLisp command for selecting mutliple files, similar to vl-directory-files?
jbuzbee
Re: Select Multiple Files
« Reply #1 on: July 18, 2007, 09:55:41 AM »
Can you use it in a sentence?  :-P
Sorry, I mean how would you use it?
James Buzbee
Windows 8
« Reply #2 on: July 18, 2007, 09:58:23 AM »
Not sure I know what you mean, but perhaps dcl_MultiFileDialog.
{ shrugs }
CADaver
« Reply #3 on: July 18, 2007, 10:06:08 AM »
I use a function from Robert McNeel's DOSLIB functions HERE
Looks sorta like this:
(dos_getfilem "Select File" (getvar "DWGPREFIX") "Drawing Files (*.DWG)|*.DWG")
I'm sure someone here can code up a lispy replacement, I think I saw one somewhere.
Guest
« Reply #4 on: July 18, 2007, 10:31:13 AM »
That's what I was looking for.
Thanks!
*I was just thumbing throw the DosLib help.  Wonder how I missed that one.  :?*
  • Custom Title
« Reply #5 on: July 18, 2007, 10:39:14 AM »
Is that equivalent to the doslib function dos_getfilem?
CADaver
« Reply #6 on: July 18, 2007, 10:56:33 AM »
Thanks!
I use it to XREF a couple dozen files all at once, it's one of my fav's.
Guest
« Reply #7 on: July 18, 2007, 10:58:52 AM »
What version of ACAD are you running?  You can xref multiple files at once in '07 and '08.  I think you could even do it back in '05, but I'm not 100% sure about that.
« Reply #8 on: July 18, 2007, 10:59:01 AM »
Yep. I wouldn't have suggested it but I was under the impression you were already using OpenDCL, so it's already at your disposal.
Examples:
(dcl_MultiFileDialog
    (list
        "Drawings (*.dwg)|*.dwg"
        "Templates (*.dwt)|*.dwt"
    "Select the drawings(s):"
    "c:\\"
Or ...
    (list "Drawings (*.dwg,*.dwt)|*.dwg;*.dwt")
    "c:\\"
Guest
« Reply #9 on: July 18, 2007, 11:00:15 AM »
Examples:
    (list
    "c:\\"
Or ...
    "c:\\"
Do you have to add the FILE DIALOG BOX to the project?
CADaver
« Reply #10 on: July 18, 2007, 11:08:03 AM »
About half our staff is still running R2002 <edit> and dcl_MultiFileDialog is not available.
« Last Edit: July 18, 2007, 11:10:09 AM by CADaver »
« Reply #11 on: July 18, 2007, 11:13:55 AM »
No -- dcl_MultiFileDialog is a self reliant bonus function included in the OpenDCL arx run time.
PS: If you're using an older version of Object/OpenDCL the function would be named odcl_MultiFileDialog.
CADaver
« Reply #12 on: July 18, 2007, 01:30:54 PM »
Ahh cool, thanks, I'll look.
LE
« Reply #13 on: July 18, 2007, 01:54:25 PM »
And as a last resource, or if one of these days.... here is the C# alternative
[CommandMethod("GETMFILES")]
public void getmfiles()
    OpenFileDialog dlg = new OpenFileDialog("Title: Open Drawings", "", "dwg", "Your Dialog Name", OpenFileDialog.OpenFileDialogFlags.AllowMultiple);
    if (dlg.ShowDialog() != System.Windows.Forms.DialogResult.OK) return;
    string[] files = dlg.GetFilenames();
    foreach (string f in files)
        //do your stuff here
  • Custom Title
« Reply #14 on: July 18, 2007, 02:47:06 PM »
Nice! Screen shot please. :-)
