It's not located within a DWG, the effect happens across multiple files. If I close and re-open AutoCAD the dots disappear only to reappear a little later.
Quote from: ChrisCarlson on April 02, 2014, 08:01:14 AMIt's not located within a DWG, the effect happens across multiple files. If I close and re-open AutoCAD the dots disappear only to reappear a little later.http://www.theswamp.org/index.php?topic=46670.0
Quote from: ronjonp on April 02, 2014, 08:46:17 AMQuote from: ChrisCarlson on April 02, 2014, 08:01:14 AMIt's not located within a DWG, the effect happens across multiple files. If I close and re-open AutoCAD the dots disappear only to reappear a little later.http://www.theswamp.org/index.php?topic=46670.0You linked my thread?
(defun aprilfools (/ d) (setq d (rtos (fix (getvar 'cdate)) 2 0)) (if (and (eq "0401" (strcat (substr d 5 2) (substr d 7 2))) (wcmatch (strcase (getenv "username")) "YOU") ) (function to make user go crazy) ))
If they don't appear again, I bet there is some code somewhere that starts something like this... Code: [Select](defun aprilfools (/ d) (setq d (rtos (fix (getvar 'cdate)) 2 0)) (if (and (eq "0401" (strcat (substr d 5 2) (substr d 7 2))) (wcmatch (strcase (getenv "username")) "YOU") ) (function to make user go crazy) ))
