Author Topic: 3d arc, how to do it?  (Read 2563 times)
David Hall
  • Automatic Duh Generator
« on: April 24, 2006, 04:15:30 PM »
OK, i was asked to draw up a typical substation in 3d.  NO problem.  all the bus work is done, the transitions, circuit breakers, etc.  My question is how do I draw the soft connectios between the switchs and the circuit breakers in 3d?
Lin-Z
Re: 3d arc, how to do it?
« Reply #1 on: April 24, 2006, 05:01:57 PM »
I haven't really played with doing 3d arcs, but have you tried changing your UCS to a side view of the 2 parts you are connecting and creating an arc from there?
David Hall
« Reply #2 on: April 24, 2006, 05:28:18 PM »
i tried a side view, and iso. I even tried a new ucs on the plane b/t the 2 parts.  No go
Lin-Z
« Reply #3 on: April 24, 2006, 05:43:43 PM »
OK i got it to work by setting up the side view UCS, drawing a full circle, trimming and then usign the grips to make it less of a half-circle.  there has got to be an easer way tho  :-o
Bryco
« Reply #4 on: April 24, 2006, 06:03:57 PM »
I'll see if I can do a little vba tonight. I think if you pick 2 points it shouldn't be too hard to make an polyline w/ a thickness so it will hide nicely
David Hall
« Reply #5 on: April 24, 2006, 06:10:04 PM »
also, there is the height difference b/t the parts.  Good idea witht he circle though.  I will try that
RbtDanforth
« Reply #6 on: April 24, 2006, 06:18:36 PM »
Unless you use a 3d polyline you will still have to have the new UCS or create it in the regular ucs and rotate it 3d.
A nice effect, if it fits the design need, is to create the polyline and extrude a circle along a path (the polyline) then it will have 3d weight and hide nicely.
A wide or wide and thick polyline can have weirdness if you have to work with it (only the center can be picked etc). A 3d polyline also has limitations. Or did last I looked.
Bryco
« Reply #7 on: April 24, 2006, 08:04:58 PM »
Dragon you dont need a ucs, just the math to tell it what plane to be on .
Cmdrduh I would be tempted to make the height a percentage of the distance betwwen the picked points.
Getpointex is in downloads.
Sub PolyArc3d()
    Dim P1, P2, P3
    Dim MidP(2) As Double
    Dim dHt As Double, dBulge As Double '
    Dim dist As Double
    Dim oPline As AcadLWPolyline
    Dim N As Variant
    Dim dElev As Double
    Dim Pts(3) As Double
    Dim util As AcadUtility
    Set util = ThisDrawing.Utility
    P1 = GetPointEX
    P2 = GetPointEX(P1)
    dHt = ThisDrawing.Utility.GetDistance(, vbCrLf + "Type the height:")
    MidP(0) = P1(0) + 0.5 * (P2(0) - P1(0))
    MidP(1) = P1(1) + 0.5 * (P2(1) - P1(1))
    MidP(2) = P1(2) + 0.5 * (P2(2) - P1(2))
    dist = Length(P1, MidP)
    MidP(2) = MidP(2) + dHt
    P3 = MidP
    N = NormalFromPoints(P1, P2, P3)
    P1 = util.TranslateCoordinates(P1, acWorld, acOCS, False, N)
    P2 = util.TranslateCoordinates(P2, acWorld, acOCS, False, N)
    P3 = util.TranslateCoordinates(P3, acWorld, acOCS, False, N)
    dElev = P1(2)
    dBulge = Tan(dHt / dist)
    Pts(0) = P1(0): Pts(1) = P1(1)
    Pts(2) = P2(0): Pts(3) = P2(1)
    Set oPline = ThisDrawing.ModelSpace.AddLightWeightPolyline(Pts)
    oPline.SetBulge 0, -dBulge
    oPline.Elevation = dElev
    oPline.Normal = N
    oPline.ConstantWidth = 0.1
Public Function Length(Startpoint As Variant, Endpoint As Variant) As Double
    Dim Stx As Double, Sty As Double, Stz As Double
    Dim Enx As Double, Eny As Double, Enz As Double
    Dim dX As Double, dY As Double, dZ As Double
    Dim i As Integer
    If IsEmpty(Startpoint) Then Err.Raise 13
    i = UBound(Startpoint)
    If UBound(Endpoint) = i Then
        If i > 0 Then
            Stx = Startpoint(0): Sty = Startpoint(1)
            Enx = Endpoint(0): Eny = Endpoint(1)
            dX = Stx - Enx
            dY = Sty - Eny
            If i = 1 Then
                Length = Sqr(dX * dX + dY * dY)
            Else
                Stz = Startpoint(2): Enz = Endpoint(2)
                dZ = Stz - Enz
                Length = Sqr((dX * dX) + (dY * dY) + (dZ * dZ))
            End If
        Else
            Exit Function
        End If
    Else
        Exit Function
    End If
End Function
Function NormalFromPoints(P0, P1, P2) As Variant
    'n = u×v = (V1-V0)×(V2-V0)
    Dim X1 As Double, X2 As Double
    Dim Y1 As Double, Y2 As Double
    Dim Z1 As Double, Z2 As Double
    Dim Unit As Double
    Dim x(2) As Double
    Dim y(2) As Double
    Dim N(2) As Double
    'Get distance from zero
    x(0) = P1(0) - P0(0): y(0) = P2(0) - P0(0)
    x(1) = P1(1) - P0(1): y(1) = P2(1) - P0(1)
    x(2) = P1(2) - P0(2): y(2) = P2(2) - P0(2)
    'get CrossProduct
    N(0) = x(1) * y(2) - x(2) * y(1)
    N(1) = x(2) * y(0) - x(0) * y(2)
    N(2) = x(0) * y(1) - x(1) * y(0)
    'Convert to unit normal
    Unit = Sqr(N(0) * N(0) + N(1) * N(1) + N(2) * N(2))
    N(0) = N(0) / Unit: N(1) = N(1) / Unit: N(2) = N(2) / Unit
    NormalFromPoints = N
End Function
RbtDanforth
« Reply #8 on: April 24, 2006, 10:11:45 PM »
Cmdr
 Are you making one of these and blocking it, or are you making many different ones to be automatically produced?
If it is not to be automatically generated umpteen times then a lisp routine (much less C variants ) might be a bit of overkill? Even then I find the direct method (you would use to actually draw a thing) better than some fancy derivation no matter how cute.
To do all that to produce a wide polyline at a perpendicular instead of a real 3d object :ugly:
Bryco
« Reply #9 on: April 24, 2006, 10:59:40 PM »
Dragon, making a solid is not difficult but it does significantly  increase the overhead.
CmdrDuh can do that easily if he wants to.
David Hall
« Reply #10 on: April 25, 2006, 09:54:54 AM »
I intend to extrude a circle along the arc once I figure out how to do it.  Im going to try the code above and see what happens.  Thanks everyone, I'll keep you posted.
BTW  all the bus you see is circles extruded along a path, which was defined by bus centerlines.
David Hall
« Reply #11 on: April 25, 2006, 10:39:36 AM »
Bryco, that is awsome!!!!!!!!  it draws the arcs perfectly.  What I find interesting, is you did it through code, yet I couldn't get it to draw manually.  My goal was to figure out how to do it manually, then write code.  Thnks
David Hall
« Reply #12 on: April 25, 2006, 10:49:12 AM »
What is the function of the height?  My first test there was a 12 inch height difference, which looked awesome.  The second one had a 7 foot difference, which looked weird.  I redid it with 12 and 24 inch difference (experimentation at this point) and it looked great again.  Maybe chord height?
Bryco
« Reply #13 on: April 25, 2006, 11:13:29 AM »
Thanks CmdrDuh.
The ht is used to set the bulge, that's why you may want to set the ht as a percentage of the distance between the 2 points.
After doing all your curves you will find it is easy to grip them to where you want.
BTW best manual way is to make 1 arc the way you like it. Array it a 100 to give you plenty to use. Use Align command to put it where you want it. (Enter at this prompt  "Specify third source point"
"Scale objects based on alignment points? [Yes/No] <N>:"   type y  )
Code wise I am not good at 3d translations to mimic align, but if you can do I'ld love to have that.
RbtDanforth
« Reply #14 on: April 25, 2006, 04:06:10 PM »
I don't know how it would happen in VBA but the Lisp command Trans will translate the number between the wcs, the current ucs, an object's ucs, or the display. It doesn't do hypothetical ucs's, but you could make the hypothetical ucs the current ucs and measure that.
I find it easy enough to bounce the ucs all over as needed, as it is easy to bounce it back.
I would make it and block it, that way it is always available. you can even set the ucs at the base of a regular arc and rotate the x 90 degrees, then the block will insert at 90 degrees z when inserted in the wcs.
I even wrote a little lisp routine for when I needed to insert a batch of the same block.
;insert many
(defun C:IM (/ a s r aq ax)
(setq aq  (getvar "attreq")
      A(ENTGET (CAR (ENTSEL "\tPICK BLOCK?..")))
      AX(CDR(ASSOC 2 A))
      S(CDR (ASSOC 41 A))
      R(CDR(ASSOC 50 A) )
      )(setvar "attreq" 0)
(while t (command ".insert" AX "s" S "r" PAUSE PAUSE PAUSE )(PRINC AX))
(setvar "attreq" aq)(TERPRI)
I wrote it when I had to place several hundred spotlights pointing at the various decorations in a bobslead ride.
If you make your insertion point the alignment point and match the rotation you can place hundreds in a few minutes.
