Author Topic: TEXT to REAL..  (Read 2894 times)
Andrea
TEXT to REAL..
« on: November 11, 2005, 11:21:51 AM »
Sorry, I know I have posted something similar few days ago..
but I can find a way to have the precision of 8 digit after the point.
I have this...
(setq a "2.06112265" )
I need to transform to REAL...
(read a)  = 2.06112
(atof a)  = 2.06112
How can I get the precision...in REAL... :oops:
note: my LUPREC variable is set to 8
Keep smile...
Re: TEXT to REAL..
« Reply #1 on: November 11, 2005, 12:09:04 PM »
The value is only displayed truncated ... the value is correct in the variable .. to test it, try this:
(setq a "2.06112265")
!a
"2.06112265"
(setq b (distof a))
2.06112
!b
2.06112
(rtos b 2 8)
"2.06112265"
Andrea
Re: TEXT to REAL..
« Reply #2 on: November 11, 2005, 01:14:38 PM »
!a
"2.06112265"
(setq b (distof a))
2.06112
!b
2.06112
(rtos b 2 8)
"2.06112265"
thanks Keith..
but ho can I divide 1 by b ??
Keep smile...
Re: TEXT to REAL..
« Reply #3 on: November 11, 2005, 01:41:15 PM »
(setq c (/ 1.0 (distof b)))
Andrea
Re: TEXT to REAL..
« Reply #4 on: November 11, 2005, 01:54:56 PM »
Keith...
b is alraydy in REAL...I think you want write this..
(setq c (/ 1.0 b))
but the result is..
0.485172
and must be 0.485172486
also, if i write
(rtos c 2 8)I obtain this result..."0.48517249"
not better..
I need to do this..
(/ 1 "2.06112265")
to have the exact result....
"0.485172486"
Keep smile...
LE
Re: TEXT to REAL..
« Reply #5 on: November 11, 2005, 02:02:09 PM »
What are you doing [or trying to do] ?.... is that value going for an output?.... or is for an internal use?
Re: TEXT to REAL..
« Reply #6 on: November 11, 2005, 02:45:04 PM »
Quote from: Andrea
(/ 1 "2.06112265")
"0.485172486"
Andrea, the true value is stored in the variable. You may not 'see' it but, rest assured, the computer does. To verify this, set the precision that RTOS outputs to a higher value:
(setq c (/ 1.0 b))
0.485172
(rtos c 2 16)
"0.4851724859750583"
Re: TEXT to REAL..
« Reply #7 on: November 11, 2005, 03:19:02 PM »
Andrea, Indeed you are correct, I had meant to use (distof a) instead.
16 is the smallest accuracy you can obtain in rtos, unless it has changed in recent versions ...
Andrea
Re: TEXT to REAL..
« Reply #8 on: November 11, 2005, 04:27:55 PM »
OK....so if I understand....
(setq c (/ 1.0 b))
0.485172
is in fact 0.4851724859750583
but it do not showing me all right ?
to see all digit..i need to do..(rtos c 2 16)
ti have..."0.4851724859750583"
so the final result of this will be...
(setq d (rtos (/ 1.0 b) 2 16))
even b not showing all digit..
isn't it ?
thanks. :roll:
« Last Edit: November 11, 2005, 04:40:13 PM by Andrea »
Keep smile...
Re: TEXT to REAL..
« Reply #9 on: November 11, 2005, 04:47:21 PM »
exactly
Andrea
Re: TEXT to REAL..
« Reply #10 on: November 14, 2005, 07:41:59 PM »
finally...
thanks... :lol:
Keep smile...
