Author Topic: Divide the closed area into the same area of the same width  (Read 1938 times)
ssdd
  1. (defun c:tt( /)
  2. (if (and (setq ss (ssget (list (cons 0 "LWPOLYLINE")(cons 8 "test"))))
  3.          (setq mfk 3000)
  4.          (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  5.          )
  6.   (progn
  7.     (setq  pts(mapcar 'Get-PlineVer lst)
  8.            p1 (apply 'mapcar (cons 'min (apply 'append pts)))
  9.            p9 (apply 'mapcar (cons 'max (apply 'append pts)))
  10.            p3 (list (car p9)(cadr p1))
  11.            n  (fix (/ (- (cadr p9)(cadr p1)) mfk))
  12.            i 1
  13.            l1 nil
  14.     )
  15.     (repeat n
  16.       (setq b1 (list (car p1) (+ (cadr p1) (* i mfk)))
  17.             b3 (list (car p9) (+ (cadr p1) (* i mfk)))
  18.             l1 (cons (list b1 b3) l1))
  19.       (entmakex (list (cons 0 "LWPOLYLINE")
  20.                 (cons 100 "AcDbEntity")
  21.                 (cons 100 "AcDbPolyline")
  22.                 (cons 90 2 )
  23.                 (cons 10 b1)
  24.                 (cons 10 b3)
  25.                 (cons 8 "test")
  26.      ))(setq i (1+ i))
  27.       )
  28.
  29.     ))
ribarm
  • Marko Ribar, architect
Re: Divide the closed area into the same area of the same width
« Reply #1 on: June 07, 2018, 09:08:50 AM »
It is possible, but my routine works correct only with convex or similar shaped lwpolylines... Sorry I can't post the code... :(
M.R. on Youtube
ssdd
« Reply #2 on: June 09, 2018, 09:38:57 AM »
Thank ribarm!
ribarm
« Reply #3 on: June 09, 2018, 06:04:09 PM »
I improved my routine a little...
Regards, M.R.
M.R. on Youtube
ssdd
« Reply #4 on: June 09, 2018, 09:17:18 PM »
Thank ribarm!Progress in learning.
dussla
« Reply #5 on: June 10, 2018, 02:36:21 AM »
http://www.kimprojects.com/product/divide-area-autocad/
i bought them ~ that is good ~
I attach the information so that you may want this.
dussla
« Reply #6 on: June 10, 2018, 03:45:25 AM »
thank you for good info ~~
https://www.semanticscholar.org/paper/Testing-block-subdivision-algorithms-on-block-Wiseman-Patterson/3fe399077c6235235631e96408b15c77879be76e/figure/0
https://www.sciencedirect.com/science/article/pii/S1364815211001447
Is it difficult to make code like this possible?
ribarm
« Reply #7 on: June 10, 2018, 08:22:46 AM »
@dussla
I haven't done anything yet with AI (artificial intelligence) for CAD, but I think that your examples are too complex for PC... Some sort of manual drawing is necessary... All you could do is to try to divide area by some kind of grid - I used simple orthogonal scheme and still there may occur some errors... Still if I haven't already showed gif, I'll attach it here just for an info presentation...
Regards, M.R.
M.R. on Youtube
