Author Topic: memory size in autocad  (Read 3225 times)
viva
« on: May 10, 2007, 02:57:18 AM »
hi everybody,
          i am finding problem while georeferencing the images in autocad. the images is in .Tiff format and the size of the image is 850 MB. iam interested to do the georeference through batch mode.but it isnt working.After first image georeferenced, it shows an runtime error " abnormal program termination". This is because of memory problem.
 i am trying to make the memory free,once the first image was over thru lisp.
can anyone give me suggestion to overcome the problem
regards
viva
Adesu
Re: memory size in autocad
« Reply #1 on: May 10, 2007, 03:19:17 AM »
Hi viva,
I'm not really this answerd would help you and true, how about doslib function
look this
dos_mem
Returns a list containing information about current available memory. The function returns information about both physical and virtual memory. Use the rtos function to convert the return values to strings.
Syntax
(dos_mem)
Parameters
n/a
Returns
A list of numbers describing the current state of memory if successful. The return values are as follows:
Memory Load
 The percent of memory in use (integer).
Total Physical
 Total bytes of physical memory.
Available Physical
 Available bytes of free physical memory.
Total Page File
 Total bytes of the paging file.
Available Page File
 Available bytes in the paging file.
Total Virtual
 Total user bytes of address space.
Available Virtual
 Available, free user bytes of address space.
nil on error.
Example
Command: (dos_mem)
(27 5.3633e+008 3.90562e+008 1.30926e+009 1.18208e+009 2.14735e+009 2.06644e+009)
hi everybody,
regards
viva
viva
« Reply #2 on: May 10, 2007, 04:42:27 AM »
while typing the dos_mem command in the command prompt, its showing unknown command, can u tell me the reason
regards
viva
« Reply #3 on: May 10, 2007, 04:51:47 AM »
Do you have Dos_LIb loaded ?
added:
and the command line command is
(dos_mem)
« Last Edit: May 10, 2007, 04:58:17 AM by Kerry Brown »
Adesu
« Reply #4 on: May 10, 2007, 04:56:46 AM »
regards
viva
it's free download,try this
Robert McNeel & Associates
3670 Woodland Park Avenue North
Seattle, WA 98103
Phone: (206) 545-7000
FAX: (206) 545-7321
Internet: www.mcneel.com
Support: dale@mcneel.com
viva
« Reply #5 on: May 10, 2007, 06:11:17 AM »
thanks for ur kind help. actually dos_mem is used to know the information abut the memory. my requirement is to free the memory. i had searched in doslib i cant able 2 identify. can u suggest me
regards
viva
« Reply #6 on: May 10, 2007, 07:24:52 AM »
You can attempt to free memory, or I should say run the garbage collector by using (gc)
viva
« Reply #7 on: May 10, 2007, 07:40:34 AM »
can u explain me some what briefly
regards
viva
« Reply #8 on: May 10, 2007, 08:47:00 AM »
You can find this in your Autolisp Developer's Guide.
 (gc) Forces a garbage collection, which frees up unused memory
Other suggestions would be.. make sure you are using local variables where you can.
Setting global variables to nil immediately when you are done with them and running (gc).
Didge
« Reply #9 on: May 10, 2007, 09:34:30 AM »
I guess this isn't the answer you were looking for but I would suggest you try down-sampling the images if at all possible, 850mb is a huge image for any application to handle.
Ironically I've watched 90 minute movie files smaller than that  :-o
Think Slow......
scottcd
« Reply #10 on: May 10, 2007, 05:02:42 PM »
Have you considered converting them to an ECW file.
Handles large images really well, and still allows georeferencing.
I think the website is www.ermapper.com
Cheers
Scott
AutoCAD Dos R9 - 2018 and BricCAD 18.2
