Author Topic: Auto load ARX  (Read 7016 times)
77077
Auto load ARX
« on: May 07, 2015, 11:10:41 AM »
Hi all
Operating system contains 32 and 64 - bit version , autoCAD contains  R15~ R20 version .
How to automatically load matching arx ?
(defun S::STARTUP ()
    ((= (atoi (substr (getvar "acadver") 1 2))17)
      (if (not (member "OpenDCL.17.arx" (arx)))
        (if (findfile "OpenDCL.17.arx")
          (arxload "OpenDCL.17.arx")
    ((= (atoi (substr (getvar "acadver") 1 2))18)
      (if (not (member "OpenDCL.18.arx" (arx)))
        (if (findfile "OpenDCL.18.arx")
          (arxload "OpenDCL.18.arx")
I need for my CAD and OS ,Automatically select the appropriate ARX.
and written this ARX patch & name  to the  acad.rx
Is possible?
« Last Edit: May 07, 2015, 09:33:48 PM by 77077 »
tombu
  • ByLayer=>Not0
Re: Auto load ARX
« Reply #1 on: May 07, 2015, 11:24:11 AM »
I'd put acad.rx files in the paths of each version.  Best way to autoload arx files.
Tom Beauford P.S.M.
Re: Auto load ARX
« Reply #2 on: May 07, 2015, 11:31:48 AM »
I don't use open dcl but maybe this .. not sure if the arx names vary per architecture.
Yup .. looks like it does.
  1. (defun s::startup (/ odcl)
  2.   (and (setq odcl (strcat "OPENDCL." (substr (getvar "acadver") 1 2) ".ARX"))
  3.        (not (member odcl (mapcar 'strcase (arx))))
  4.        (findfile odcl)
  5.        (arxload odcl)
  6.   )
  7. )
« Last Edit: May 07, 2015, 11:43:58 AM by ronjonp »
77077
Re: Auto load ARX
« Reply #3 on: May 07, 2015, 12:23:00 PM »
Yes , two methods ,1. Write the registry 2. Write to acad.rx
I need to choose which one need load for my cad and OS
77077
Re: Auto load ARX
« Reply #4 on: May 07, 2015, 12:46:26 PM »
  4.        (findfile odcl)
  5.        (arxload odcl)
  6.   )
  7. )
Thanks ,But I can't understand. If my OS is 64bit ?
Is possible?
Re: Auto load ARX
« Reply #5 on: May 07, 2015, 01:00:21 PM »
Look at the link in my previous post .. detecting the architecture is fairly easy like so:
  1. (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
  2.   "x64"
  3.   "x32"
  4. )
jbuzbee
Re: Auto load ARX
« Reply #6 on: May 07, 2015, 04:02:25 PM »
(command "OpenDCL")
James Buzbee
Windows 8
77077
Re: Auto load ARX
« Reply #7 on: May 07, 2015, 09:23:55 PM »
(command "OpenDCL")
I'm not use for opendcl
77077
Re: Auto load ARX
« Reply #8 on: May 08, 2015, 06:43:29 AM »
  2.   "x64"
  3.   "x32"
  4. )
Thanks ronjonp
XLRX_API.R16.x32.arx is for cad2004~2006
XLRX_API.R2005.arx is for cad2005
SO if my cad version is cad2005 , that need load XLRX_API.R2005.arx  not XLRX_API.R16.x32.arx  ????
I'm a Newt ,I need a fish ,  can you give me ?
Re: Auto load ARX
« Reply #9 on: May 08, 2015, 10:31:01 AM »
Just thinking outside the box but .. why don't you rename those earlier versions to match the naming convention that uses (substr (getvar "acadver") 1 2) .. that would simplify things.
This should work for the file list you posted above .. but I'd still recommend using a standard naming convention.
  1. (defun s::startup (/ a f v v2)
  2.   (and (setq a (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
  3.                  ".X64.ARX"
  4.                  ".X32.ARX"
  5.                )
  6.        )
  7.        (setq v (substr (ver) 13 4))
  8.        (setq v2 (substr (getvar "acadver") 1 2))
  9.        (setq f (strcat "XLRX_API.R"
  10.                        (cond ((wcmatch v "2005,2006") (strcat v ".ARX"))
  11.                              ((= v "2008") (strcat v a))
  12.                              ((strcat v2 a))
  13.                        )
  14.                )
  15.        )
  16.        (findfile f)
  17.        (not (member (strcase f) (mapcar 'strcase (arx))))
  18.        (arxload f)
  19.   )
  20. )
« Last Edit: May 08, 2015, 11:05:33 AM by ronjonp »
irneb
Re: Auto load ARX
« Reply #10 on: May 08, 2015, 11:06:56 AM »
SO if my cad version is cad2005 , that need load XLRX_API.R2005.arx  not XLRX_API.R16.x32.arx  :? ?
Agreed about renaming ... Can you rename the ARX files to use ACad's internal version numbers instead of those external 20## numbers?
If not you could build the possible version numbers using this:
  1. (defun get-acadversions (/ r i j L a)
  2.   (setq r (atof (getvar "acadver"))
  3.         i (atoi (rtos r))
  4.         j (atoi (rtos (* 10 (- r i))))
  5.         L (list (itoa i) (strcat (itoa i) "." (itoa j))))
  6.   (if (>= i 15)
  7.     (setq L (cons
  8.               (cond ((= i 15)
  9.                      (strcat "200" (cond ((= j 1) "1i") (t (itoa j)))))
  10.                     ((< i 19)
  11.                      (itoa (+ 2004 (* (- i 16) 3) j)))
  12.                     (t
  13.                      (itoa (+ 2013 (* (- i 19) 2) j))))
  14.               L)))
  15.   (append L (mapcar '(lambda (s) (strcat "r" s)) L)))
Then use a function to search for the first file found using those numbers. Something like this:
  1. (defun find-by-ver (pre post)
  2.   (vl-remove 'nil (mapcar '(lambda (v) (findfile (strcat pre v post)))
  3.                           (get-acadversions))))
You could call it thus in your scenario:
  1. (if (setq found (find-by-ver
  2.                   "XLRX_API."
  3.                   (strcat (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
  4.                             "x64"
  5.                             "x32")
  6.                           ".arx")))
  7.   (arxload (car found)))
Re: Auto load ARX
« Reply #11 on: May 08, 2015, 12:22:46 PM »
Nice idea & code Irné - I see you have cracked the AutoCAD release numbering pattern :-)
Perhaps another way to write it to avoid the reliance on Autodesk being consistent...
  1. (defun acadversions ( / a b c d )
  2.     (setq a (getvar 'dimzin)
  3.           b (atof (getvar 'acadver))
  4.     )
  5.     (setvar 'dimzin 0)
  6.     (setq c (list (substr (ver) 13 (- (strlen (ver)) 17)) (rtos b 2 0) (rtos b 2 1))
  7.           d (append c (mapcar 'strcat '("r" "r" "r") c))
  8.     )
  9.     (setvar 'dimzin a)
  10.     d
  11. )
Re: Auto load ARX
« Reply #12 on: May 08, 2015, 12:39:58 PM »
Nice Lee :) .. this is the way I'd write it.
  1.
  2. (defun acadversions (/ l m a c)
  3.   (setq l (getvar 'dimzin)
  4.         m (atof (getvar 'acadver))
  5.   )
  6.   (setvar 'dimzin 0)
  7.   (setq a (list (substr (ver) 13 (- (strlen (ver)) 17)) (rtos m 2 0) (rtos m 2 1))
  8.         c (append a (mapcar 'strcat '("r" "r" "r") a))
  9.   )
  10.   (setvar 'dimzin l)
  11.   c
  12. )
  13. (acadversions)
  14.
Re: Auto load ARX
« Reply #13 on: May 08, 2015, 01:17:53 PM »
Haha!  :-D
Thanks Ron  :-)
alanjt
  • Standby for witty remark...
Re: Auto load ARX
« Reply #14 on: May 08, 2015, 04:27:00 PM »
Here's my lazy method...
;; DosLib
(vl-some (function (lambda (dos)
                     (or (vl-position dos (arx))
                         (not (vl-catch-all-error-p (vl-catch-all-apply 'arxload (list dos))))
         (vl-directory-files "C:\\alan\\arx\\" "DOSLIB*ARX")
Dropbox
