(defun ortho-p1 ( ent fuz )
( (lambda ( fun ) (fun (entget ent) fuz))
(lambda ( enx fuz / ang vt1 vt2 )
(or (not (and (setq vt1 (assoc 10 enx))
(setq enx (cdr (member vt1 enx)))
(setq vt2 (assoc 10 enx))
(and (equal 0.0 (cdr (assoc 42 enx)) fuz)
(setq ang (rem (angle (cdr vt1) (cdr vt2)) (/ pi 2.0)))
(or (equal 0.0 ang fuz) (equal (/ pi 2.0) ang fuz))
(fun enx fuz)
(defun ortho-p2 ( ent fuz / ang end par )
(setq end (vlax-curve-getendparam ent)
par 0
(while
(< par end)
(setq ang (rem (angle '(0.0 0.0) (vlax-curve-getfirstderiv ent par)) (/ pi 2.0)))
(equal '(0.0 0.0 0.0) (vlax-curve-getsecondderiv ent par) fuz)
(setq par (1+ par))
(= par end)
(defun ortho-p3 ( ent fuz )
( (lambda ( fun ) (fun ent fuz 0 (vlax-curve-getendparam ent)))
(lambda ( ent fuz par end / ang )
(or (= par end)
(and (setq ang (rem (angle '(0.0 0.0) (vlax-curve-getfirstderiv ent par)) (/ pi 2.0)))
(fun ent fuz (1+ par) end)
(defun VvK_Pline_OrtoP (EntNam FuzFac / VtrLst)
(setq VtrLst (cdrs 10 (entget EntNam)))
(vl-every (function (lambda (e1 e2)
(or (equal (car e1) (car e2) FuzFac)
(equal (cadr e1) (cadr e2) FuzFac)
VtrLst
(cdr VtrLst)
(defun c:test ( / sel EntNam)
(if (setq sel (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))
(setq EntNam (ssname sel 0))
(princ "\northo-p1 \t") (princ (ortho-p1 EntNam 1e-8))
(princ "\northo-p2 \t") (princ (ortho-p2 EntNam 1e-8))
(princ "\northo-p3 \t") (princ (ortho-p3 EntNam 1e-8))
(princ "\nALE_Pline_OrtoP\t") (princ (ALE_Pline_OrtoP EntNam 1e-8))
(princ "\nVvK_Pline_OrtoP\t") (princ (VvK_Pline_OrtoP EntNam 1e-8))
@roy: ok seem all ok
@Vovka: I have bad results in many condition, try also in IsOrtho.dwg
@Lee: I have renamed your functions to test,
in "D" case (side not perfect ex.: 499.99999999) i have this result, what do you think about?
ortho-p1 T
ortho-p2 nil
ortho-p3 nil
and
ALE_Pline_OrtoP T
VvK_Pline_OrtoP T
