Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
drap slection set of lines on selection set of 3dpolylines
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: drap slection set of lines on selection set of 3dpolylines (Read 1806 times)
motee-z
Newt
on:
August 27, 2015, 03:42:23 PM »
Hello
i need help to drape a selection set of lines on a selection set of 3d polylines as in attached drawing
any help will highly appriciated
Logged
motee-z
Newt
Re: drap slection set of lines on selection set of 3dpolylines
Reply #1 on:
August 28, 2015, 04:08:26 PM »
still hoping someone who can help me
Logged
ymg
Guest
Reply #2 on:
September 03, 2015, 02:21:23 PM »
motee-z,
Use your blue lines as fences to select your polylines.
Each line will return a selection set, use ssnamex to get the
2d intersection points between lines and polylines.
Use these points to get the z value using the curves function.
ymg
Logged
ymg
Guest
Reply #3 on:
September 04, 2015, 12:04:31 PM »
Here is some code to get you started.
Beware that there is no error trapping.
Also the method to get the z using (osnap p "_appint")
is sensitive to zoom level.
Code - Auto/Visual Lisp:
[Select]
;; Modified a routine by AlanJT ;
;; Will entmake a 3d polyline given, 3d point list l ;
;; Returns ename of polyline ;
defun
mk_3dp
l
p
if
length
l
1
progn
entmakex
0
"POLYLINE"
70
8
foreach
p l
entmakex
list
0
"VERTEX"
cons
10
p
70
32
entmakex
0
"SEQEND"
entlast
;; Main Routine ;
defun
c:test
i j ent fen ss ss1 p pol lst itm int
setq
ss
ssget
"_X"
0
"LINE"
8
"LAY"
repeat
setq
i
sslength
ss
setq
ent
entget
ssname
ss
setq
i
1-
i
fen
list
cdr
assoc
10
ent
cdr
assoc
11
ent
ss1
ssget
"_F"
fen '
0
"POLYLINE"
pol
nil
repeat
setq
j
sslength
ss1
setq
lst
ssnamex
ss1
setq
j
1-
j
foreach
itm lst
setq
itm
cdddr
itm
foreach
int itm
setq
p
cadr
int
vl-cmdf
"_ZOOM"
"_C"
p
"200X"
setq
pol
cons
osnap
p
"_appint"
pol
vl-cmdf
"_ZOOM"
"_P"
mk_3dp pol
ymg
Logged
motee-z
Newt
Reply #4 on:
September 04, 2015, 02:01:54 PM »
you are great ymg thank you for your reply
it works fine
Logged
ymg
Guest
Reply #5 on:
September 04, 2015, 02:37:15 PM »
motte-z,
There might be some funny results when the blue lines
intersects with the newly created 3d poly.
ymg
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
