Author Topic: Quick Question  (Read 2319 times)
wannabe
Quick Question
« on: April 07, 2009, 07:58:24 AM »
When using an application that requires opening and closing of files, from within AutoCAD, do we use the standard openFileDialogs and saveFileDialogs in the .NET 3.5 framework or is there some AutoCAD alternatives or legislation that I am compelled to adhere to?
Cheers.
Bobby C. Jones
Re: Quick Question
« Reply #1 on: April 07, 2009, 08:24:49 AM »
Cheers.
Autodesk does provide alternatives, which I use, but you do have the freedom to use the Microsoft versions if you so desire.
Bobby C. Jones
wannabe
Re: Quick Question
« Reply #2 on: April 07, 2009, 10:53:06 AM »
Thanks. I've been reading the ARX .NET help files and it says something about all inheriting or implementing a certain class/interface.
I'll re-read and hit you with more questions.
Re: Quick Question
« Reply #3 on: April 07, 2009, 11:07:50 AM »
Maybe this will help a little.
[ http://www.theswamp.org/index.php?topic=22172.0 ]
I like the windows version, just for the speed of it.
Glenn R
Re: Quick Question
« Reply #4 on: April 07, 2009, 06:39:17 PM »
The golden rule as far as UI is concerned, IMO, is make yours the same as the AutoCAD user expects, which means for this case, use the openfiledialog supplied by Autodesk. Some of the benefits include the preview icon area, favourites etc.
