Code Red => AutoLISP (Vanilla / Visual) => Topic started by: ArgV on January 06, 2010, 10:04:58 AM
Hello.
I didn't find anything right off by searching, and not even sure if this realistic or not, but I want to be able to swap out all blocks with xrefs (pulled from a folder of my choosing). I got it to *kinda* work, but obviously if block already exists I need to copy the remaining xref rather than do the vla-attachexteralreference property.
but I'd rather see if anyone knows if this is even possible.
thank you,
ArgV
Have you tried the ExpressTools command "blocktoxref"?
NO! :) I was typing stuff like that trying to see if there was a command like that. Cool, I'll try that. :)
thank you.
