Author Topic: digging in the paper space  (Read 1678 times)
DEVITG
« on: April 05, 2008, 08:53:19 AM »
By this
File_name is "F:\\lisp\\xxxx\\room 004.dwg"
   (setq odbx (vlax-get-or-create-object
(strcat "ObjectDBX.AxDbDocument."
(substr (getvar "ACADVER") 1 2))))
    (vla-open odbx file_name)
(setq model (vla-get-modelspace odbx))
    (setq each-at (vla-item model 2))
I can get  an object , and by
(vlax-for each-at  model
I can loop to each object to work on it , as to check for text and do a search
How can I do the same with objects at each Paper space layouts ??
Re: digging in the paper space
« Reply #1 on: April 05, 2008, 09:37:38 AM »
Try this:
(vlax-map-collection
  (vla-get-PaperSpace
    (vla-get-ActiveDocument (vlax-get-Acad-Object)))
  'vlax-dump-object
gile
  • Marseille, France
« Reply #2 on: April 05, 2008, 09:49:15 AM »
Salud,
You can iterate through the layouts collection.
Each layout is almost  constituted by two objects : a plot configuration (layout object) and a block which countains the graphical objects (viewports...)
The following example print all graphical objects for each layout of the document
(vlax-for layout (vla-get-Layouts odbx)
  (and (/= (setq name (vla-get-Name layout)) "Model")
       (princ (vla-get-Name layout))
       (vlax-for obj (vla-get-Block layout)
(print (vla-get-ObjectName obj))
       (terpri)
DEVITG
« Reply #3 on: April 05, 2008, 10:21:26 AM »
Gile , I got it , thanks for it .
