Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Columbia on October 13, 2004, 10:02:39 AM
This is for all you guru's among geeks :P
I want to play a *.wav file from my VisualLISP function. How does one go about doing that. I'm already familiar with the DOSLib coolness, however I want to be able to ship this out to another user who may or may not have DOSLib, and I don't want to ship the DOSLib arx to them.
Any and all help here would be appreciated. Thanks.
All I have is a VBA thingie:
Private Declare Function PlaySound Lib "winmm.dll" (ByVal lpszName As String, ByVal hModule As Long, ByVal dwFlags As Long) As Long
Private Const SND_ASYNC = &H1 ' play asynchronously
Private Const SND_FILENAME = &H20000 ' file name
Private Const NO_ERROR = 0
Private Sub PlayItSam()
PlaySound "D:\WINNT\Media\notify.wav", ByVal 0&, SND_FILENAME Or SND_ASYNC
http://theswamp.org/phpBB2/viewtopic.php?t=993&highlight=wav+file
and
http://theswamp.org/phpBB2/viewtopic.php?t=370&highlight=wav+file
Out of curiosity how would you do it using doslib?
--ImaJayhawk
Really, really simple...
(dos_wav "filename.wav")
Stig, CAB, Thanks. I appreciate the info.
...But (there's always a "but", isn't there?) what I really wanted was a method of interacting with Win32API through VLISP to play it. I would still have to ship this file VBA file along with the vlx.
Any thoughts?
Have you tried using Rundll32 to play the file through the winmm.dll ?
Ummm..... Keith you've caught me completely ignorant. I don't even know what Rundll32 is, nevermind trying to use it.
rundll32 is a program that you can use to run exported dll functions (typically C and/or C++ functions) winmm.dll is the dll that contains the function to play multimedia files. I have not explored how to make it happen, but I am quite sure given the correct syntax it would be possible.
Pardon my ignorance, but how do I get that to run?
type VBAMAN , click NEW then click VBA EDITOR. Paste that code into the IDE put your cursor somewhere in the sub portion of it and press F5
Okay...now what if I wanted to put this in as part of a reactor? Particularly when an object is erased?
Private Sub AcadDocument_ObjectErased(ByVal ObjectID As Long)
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
If (VBA.UCase$(CommandName) = "ERASE") Then
Call PlayItSam
End If
Even when I tried the original code, I never got a macro to execute. I'm not familiar with VBA, so I apologize in advance. But I followed the procedure Bob outlined, but when I hit F5, I don't have anyt macro to select to run. :dummy:
try inserting this in a new module in the vbaide
Option Explicit
Public Sub MakeANoise()
PlaySound "c:\windows\media\ding", ByVal 0&, SND_FILENAME Or SND_ASYNC
That works! Thanks...now to put that with the Erase reactor...after work...
if you try to use simple beep sound..
you can use (acet-sys-beep Yoursoundhere)
or
(startapp "c:/windows/system32/sndrec32.exe /play /close" "C:/windows/media/tada.wav")
but this will show the soundrecorder...
maybe it have a switch / to play background...but i don't know..
One more time ... ACET* = Evil.
If you don't want to roll your own functions use DOSLIB (http://www.mcneel.com/cgi-bin/download.cgi?doslib)'s (dos_wav filename) function, but please don't use the ACET* crap, you're just begging for problems down the road and your users are the ones that will pay.
Call PlayItSam
End If
This will not work the way it should, so please disregard.
See this thread ....
http://www.theswamp.org/forum/index.php?topic=993.0
lol, this thread reminds me that I used to have the sound of a toilet flush everytime members of Microstation / PDS group changed projects (I had written a project management utility to map the network, modify the registry etc). I didn't keep the code active very long but it was funny while it was enabled.
:-D
MP could you explain exactly why ACET* is crap ?
I'm new with it...and for my own...seem to work.
