o i forgot a question i wanted to ask. i like using acaddoc.lsp but would like to move it from program files to where my custom stuff is. if i keep a copy in program files it reads from it first because it is on top in my search path. if i move my custom folder to the top it reads from that but is there any danger in having it read from my custom folder first?
I would suggest that you keep the primary acaddoc.lsp where it is. What you can do is keep your secondary acaddoc.lsp, (call it Eloquintetdoc.lsp) and keep that file in your custom folder.
Then in the acaddco.lsp just use (load "mycustomfolderpath\\Eloquintetdoc")
I have a separate file "vbacommands.lsp" where I keep all my vba stuff and I just call that in my acaddoc.lsp ~ (load "vbacommands") ~ keeps things nice and simple.
Regarding your hatch vlx's (I didn't know you could compile a hatch into a vlx so I just learned summat !) ~ are you using autoload for them also ? Doesn't autoload expect both a filename and a command list ? how you apply a command to a hatch pattern ? Have you tried using the plain old "load" command with those files ?
