Author Topic: MODAL FORMS frame, How do the cross chart files exempt rewrite down the use?  (Read 3689 times)
hunterxyz
Uses OpenDCL to make MODAL the FORMS frame dialog box,
Although, may continuously demonstrate in the screen,
But the switch files, must rewrite load odcl file,
did not know how means has to be allowed to process?
Requests fellow masters to be able to help to explain, thanks!
jbuzbee
Do you want a modeless form?  Floating form that doesn't need to be closed to interact with AutoCAD??
If so, just open the project in the editor, create a new modeless form and copy/past the controls off the modal form.  Don't forget to set all the events, and that the var names have changed.
Hope that's what you were looking for.
James Buzbee
Windows 8
hunterxyz
how set ? thank!
hunterxyz
How are Exempts rewrites down?
