Author Topic: getting the point within the line...  (Read 1446 times)
rainier
« on: October 01, 2007, 01:12:17 AM »
what function to get the point (xyz) with the line???
like that --->  ____._______
ohh! i mean is i have a distance on the point but i dont have a location.. getting the (XYZ)
any idea guys?? please help.. thanks
« Last Edit: October 01, 2007, 01:16:58 AM by rainier »
FengK
Re: getting the point within the line...
« Reply #1 on: October 01, 2007, 01:52:17 AM »
if i understood you correctly, look up function polar.
from ref:
(polar pt ang dist)
Arguments
pt
A 2D or 3D point.
ang
An angle expressed in radians relative to the world X axis. Angles increase in the counterclockwise direction, independent of the current construction plane.
dist
Distance from the specified pt.
Return Values
A 2D or 3D point, depending on the type of point specified by pt.
« Last Edit: October 01, 2007, 01:55:11 AM by Kelie »
« Reply #2 on: October 01, 2007, 09:12:59 AM »
Polar requires the start point, angle and distance while vlax-curve-getPointAtDist requires the object and distance.
(setq p2 (polar p1 angle dist))
(setq p2 (vlax-curve-getPointAtDist ent dist))
 Note that the vlax-curve-getPointAtDist uses the start point of the object when created and may not be the point
 you think it is.
CADaver
« Reply #3 on: October 01, 2007, 11:42:13 AM »
hmmm... ???x2
Anyway, as Alan points out vlax-curve-getPointAtDist uses the start point so I still use the old CAL function.
