Author Topic: I don't remember how...  (Read 7954 times)
craigr
Re: I don't remember how...
« Reply #15 on: October 16, 2008, 08:59:35 AM »
Not my dime..
Believe me, if I could have the 'real' thing, I would. - I get tired of being bit by that snake.
craigr
Alan Cullen
« Reply #16 on: October 16, 2008, 09:01:22 AM »
Blue...go check out the FAQ on the difference between LT and full blown. If it's not up to date, then tell Tiger to pull her finger out and update it. Second thoughts...don't do that unless you like the smell of fish on your face.... :lmao: :lmao: :lmao:
sinc
« Reply #17 on: October 16, 2008, 09:45:40 AM »
I have two layers, one called 'Pink' & the other 'Green'. I would like to eliminate 'Pink' by merging it into 'Green'.
So I do the LayMrg command and select Pink, then hit enter then select Green and hit enter. - Nothing has changed.
After you select the second layer and hit ENTER, Autocad should prompt you with:
******** WARNING ********
You are about to merge layer "Pink" into layer "Green".
Do you wish to continue? [Yes/No] <No>:
If you simply hit ENTER at that point, the command will be aborted and nothing will happen.  You must answer YES.
craigr
« Reply #18 on: October 16, 2008, 09:54:19 AM »
Yep, that is just what I am doing, but it doesn't change either one.
When I do this, shouldn't both be on the 'pink' layer?
craigr
craigr
« Reply #19 on: October 16, 2008, 02:08:25 PM »
See the attached..
THIS is what I am talking about. - Of course there are MANY of these throughout the dwg.
I want only ONE layer called 'RoomNumbers'.
How can I get this?
craigr
Rob...
« Reply #20 on: October 16, 2008, 02:14:45 PM »
Draw 2 lines, 1 on artag and 1 on RoomNumbers. Use Layer Merge and select the line on artag, right click, then select the 1 on RoomNumbers. Right click and type "y".
CAD Tech
craigr
« Reply #21 on: October 16, 2008, 02:43:38 PM »
That is what I have been doing all along - I SWEAR.
So, I followed your instructions to the letter on the dwg that I posted - and it worked!!!
So I went back to my original dwg and tried it there and it didn't work. I 'craps out' without an error. I just doesn't give you the confirmation option to answer yes or no.
So I know there must be a difference between the two dwgs.
After trying several things, I discovered that when a layer in my original dwg called 'TITLE_BLOCK' is locked, LayMrg doesn't work. As soon as I unlock it, LayMrg works fine.
I don't know why that would make a difference, but it does.
Thanks for the help though, at least I can have what I want now.
EDITED ----
Now I think it has to do with a block on that 'Title_Block' Layer.
If I delete that copyright block - The LayMrg works.
It must be something about that Block - near as I can figure.
craigr
« Last Edit: October 16, 2008, 03:05:27 PM by craigr »
Kate M
« Reply #22 on: October 16, 2008, 04:03:13 PM »
did you ATTSYNC after exiting the block editor ?
Apparently, that is not an option in LT.
craigr
Have you considered buying a real version of AutoCAD?   :roll:
:pissed:
 :wink:
Slim©
  • The Dude Abides...
« Reply #23 on: October 16, 2008, 05:20:23 PM »
Maybe try LAYTRANS. It transfers entities from one layer to another and then deletes the one that is empty.
Kate M
« Reply #24 on: October 16, 2008, 05:50:06 PM »
Not an LT command. :| (It's part of the Standards management tools.)
« Reply #25 on: October 16, 2008, 05:58:19 PM »
How would you change the layer of an attribute in LT?  I don't know of a way ( without code ), and that may help in the future, as that seems to be what is the problem in the block posted in this thread.
« Reply #26 on: October 16, 2008, 06:06:17 PM »
would LT not support ATTEDIT?
« Reply #27 on: October 16, 2008, 06:13:12 PM »
I thought was the way, but when I tried it this morning it didn't have the layer prompt, but now it did.  Attedit didn't do it on my system, but -attedit did.
Edit: Not LT tested.
Kate M
« Reply #28 on: October 17, 2008, 02:26:28 PM »
Block editor.
« Reply #29 on: October 17, 2008, 03:52:13 PM »
Block editor.
But once the block is inserted, the layer of the attributes can be changed to any layer.  Wouldn't the block editor only change the attribute definition's layer?  And not the one that is inserted ( and associated with a inserted block )?
