CAD Forums => CAD General => Topic started by: craigr on October 14, 2008, 02:30:48 PM
We often get floorplans from other Engineers, that we need to 'clean' the dwg of everything but the doors, walls, windows, etc..
We then take everything and put it on a new layer we name 'Floorplan'. We then purge all of the other layers.
A longstanding problem has been that every now and then, we find layer(s) that we cannot purge. I usually use the 'erase all' option, but sometimes this doesn't work. Even the qselect doesn't always do it. Of course we explode everthing as much as possible.
I recently figured out a way to find these 'phantom' entities on the bad layers, but today I don't remember what it was. Do any of you have another idea of how to find them?
At this point, I just copied the parts I want to a new title block and replace the old - but I would rather not have to go thru the process.
craigr
try using LAYWALK, and then LAYDEL, once you have identified entities on the layer(s) you wish to delete
That is the problem, we can't find anything on that layer.
craigr
Duh...
I just remembered how....
I drew a line on the layer that I want to get rid of, then selected it then 'delete layer'.
Sorry to waste your time, - I must have had a 'brain fart'.
craigr
The Laydel has a Name option so you can pick the layer from a dialog box (at least 2008 does).
LAYMRG is also helpful in this situation -- merge the offending layer with one you want to keep to be sure you don't lose any data that might be hiding on that layer.
And when all else fails, go to Owen Wengerd's Manusoft.com for 'SuperPurge', because it does super purge.
It will purge layers that have no entities but still otherwise cannot be deleted.
That's a nice tip, Kate. :)
Alright, I tried the 'LayMrg' command - a couple of times.
Either I am doing something wrong or I don't understand what it does.
I have two layers, one called 'Pink' & the other 'Green'. I would like to eliminate 'Pink' by merging it into 'Green'.
So I do the LayMrg command and select Pink, then hit enter then select Green and hit enter. - Nothing has changed.
Did I do something wrong? Am I misunderstanding what this command does?
craigr
use qselect based on layer "pink" and change every there to layer "green".
Change...P.....P...LA...GREEN....
done......
Oh..and then PURGE...just to get rid of empty layer "pink"...hoping no blocks were bought in on layer pink.......woot.....
Craig...stop dreaming about Pacific paradises...... :lmao: :lmao:
I thought of you this morning as I was scraping the HEAVY frost off the windows of my Truck - :)
As for the CAD, what I am actually trying to do is...
I have a dwg from some other company that has the room name & room number as a block with attributes, they are on 2 different layers and 2 different colors.
I want to put them on my 'standard' layer called 'roomnumbers' and have everything bylayer color.
If I explode their block, I lose the name & number. I tried going into the block editor and changing everthing from there, but that didn't work either.
I run into this often, and would LOVE to find a solution. I thought the LayMrg was it.
craigr
did you ATTSYNC after exiting the block editor ?
Apparently, that is not an option in LT.
craigr
Omaha, we have a problem.......
LT doesn't have what I was about to suggest.....
*sucks up with baby koala and stays away from the real world*
hell...it's my paradise...I can beat it, thump it, love it, as hard and as fast as I want.
Mawhawhaw
craigr
Have you considered buying a real version of AutoCAD? :roll:
Not my dime..
Believe me, if I could have the 'real' thing, I would. - I get tired of being bit by that snake.
craigr
Blue...go check out the FAQ on the difference between LT and full blown. If it's not up to date, then tell Tiger to pull her finger out and update it. Second thoughts...don't do that unless you like the smell of fish on your face.... :lmao: :lmao: :lmao:
After you select the second layer and hit ENTER, Autocad should prompt you with:
******** WARNING ********
You are about to merge layer "Pink" into layer "Green".
Do you wish to continue? [Yes/No] <No>:
If you simply hit ENTER at that point, the command will be aborted and nothing will happen. You must answer YES.
Yep, that is just what I am doing, but it doesn't change either one.
When I do this, shouldn't both be on the 'pink' layer?
craigr
See the attached..
THIS is what I am talking about. - Of course there are MANY of these throughout the dwg.
I want only ONE layer called 'RoomNumbers'.
How can I get this?
craigr
Draw 2 lines, 1 on artag and 1 on RoomNumbers. Use Layer Merge and select the line on artag, right click, then select the 1 on RoomNumbers. Right click and type "y".
That is what I have been doing all along - I SWEAR.
So, I followed your instructions to the letter on the dwg that I posted - and it worked!!!
So I went back to my original dwg and tried it there and it didn't work. I 'craps out' without an error. I just doesn't give you the confirmation option to answer yes or no.
So I know there must be a difference between the two dwgs.
After trying several things, I discovered that when a layer in my original dwg called 'TITLE_BLOCK' is locked, LayMrg doesn't work. As soon as I unlock it, LayMrg works fine.
I don't know why that would make a difference, but it does.
Thanks for the help though, at least I can have what I want now.
EDITED ----
Now I think it has to do with a block on that 'Title_Block' Layer.
If I delete that copyright block - The LayMrg works.
It must be something about that Block - near as I can figure.
craigr
craigr
:pissed:
:wink:
Maybe try LAYTRANS. It transfers entities from one layer to another and then deletes the one that is empty.
Not an LT command. :| (It's part of the Standards management tools.)
How would you change the layer of an attribute in LT? I don't know of a way ( without code ), and that may help in the future, as that seems to be what is the problem in the block posted in this thread.
would LT not support ATTEDIT?
I thought was the way, but when I tried it this morning it didn't have the layer prompt, but now it did. Attedit didn't do it on my system, but -attedit did.
Edit: Not LT tested.
Block editor.
Block editor.
But once the block is inserted, the layer of the attributes can be changed to any layer. Wouldn't the block editor only change the attribute definition's layer? And not the one that is inserted ( and associated with a inserted block )?
Ah, right. I don't remember where I heard about this first, but if you hold down CTRL and select an attribute, you can get the Properties dialog to show the properties for the attribute, not the block. Way cool. :kewl:
That does sounds cool, but it didn't work for me. It looks like it wants to, but it didn't show the attribute in the property dialog box. I say it wants to because it prints, to the command line, <cycle on> <cycle off>, which I interpret as meaning cycle through the entities.
