Author Topic: Dimstyle LIST  (Read 3438 times)
Andrea
Dimstyle LIST
« on: November 04, 2004, 12:05:35 PM »
Hi all...
I'm trying to get a list of DIMSTYLE available in the current drawing..
in LISP.
any idea ?
thanks
Keep smile...
Andrea
Dimstyle LIST
« Reply #1 on: November 04, 2004, 12:09:48 PM »
ok...sorry I found the solution....
(setq dimstyle_list (ai_table "dimstyle" 4))
but it will be interested to have any other idea..;-)
thanks :wink:
Keep smile...
Dimstyle LIST
« Reply #2 on: November 04, 2004, 12:11:04 PM »
Have a look at tblnext and tblsearch
ML
Dimstyle LIST
« Reply #3 on: November 04, 2004, 06:39:48 PM »
Do it with VBA and you can't go wrong   :D
Dimstyle LIST
« Reply #4 on: November 04, 2004, 06:52:18 PM »
Ran across this today:
(defun getdims
               (/ dim ;dimstyle
                dimcol ;dimension collection
                dwg ;current drawing
                return ;list to be returned
  (setq dwg    (vla-get-activedocument (vlax-get-acad-object))
        dimcol (vla-get-dimstyles dwg)
        return ()
  (vlax-for dim dimcol
    (setq return (append return (list (vla-get-name dim))))
  return
MikePerry
Dimstyle LIST
« Reply #5 on: November 05, 2004, 05:18:23 AM »
Quote from: CAB
Hi
CAB I really think the person who wrote that should be credited, it's only polite and proper to do so when the person is known (in my humble opinion) -
Code written by Michael K. Sretenovic, original can be found here -
http://forums.augi.com/showthread.php?p=60269#post60269
Have a good one, Mike
Dimstyle LIST
« Reply #6 on: November 05, 2004, 07:55:18 AM »
Please forgive my lazy behavior. I had no intention of slighting the person
whose post I copied. As that person did not put his or her name in the header of
the code nor claimed to be the original author. I just copied the code to my
library 'As Is'. I did not ask who the original author was and did not record
the source or the code. I thought that if the author wanted there name
associated with the code they would add it to the header of the code, I do. I
did remember where I got it as it was the same day that I copied the code but
was too lazy to go back and get the link. My apologies if I offended you or the
author. I NEVER remove the authors information and I did not intend to take any
credit for creating the code. Your comments will no doubt make me more aware
in the future.
MikePerry
Dimstyle LIST
« Reply #7 on: November 05, 2004, 07:59:51 AM »
Hi CAB
No foul / harm and I honestly know you weren't trying to pass-off as your own, I just believe it's best to quote original source if possible....
Cheers, Mike
Dimstyle LIST
« Reply #8 on: November 05, 2004, 08:16:04 AM »
Thanks Mike
I'll will try to be a better Librarian in the future.
I do collect a lot of code and code snipits but I don't do a good job of organizing them.
