Hello
I have been trying to modify this terrific lisp by Vovka so that the selected attribute is moved by a set distance.
The reason is to 'stack' the attributes when some of the other block attribute values are missing.
I wish to move the selected attributes -0.442 in the Y axis.
this is the lisp:
; Vovka http://www.theswamp.org/index.php?topic=21303.0
(defun C:MOVEATTXT (/ CE OS Ent EntProps LastPoint LastEnt *error*)
(defun *error* (msg)
(if OS
(setvar 'OSMODE OS)
(if CE
(setvar 'CMDECHO CE)
(if LastEnt
(entdel LastEnt)
(vl-cmdf "._UNDO" "_END")
(if (or (= msg "Function cancelled") (= msg "quit / exit abort"))
(setq OS (getvar 'OSMODE)
CE (getvar 'CMDECHO)
(vl-cmdf "._UNDO" "_BEGIN")
(setvar 'CMDECHO 0)
(setvar 'OSMODE 0)
(and
(progn (while (not (and (setq Ent (nentsel "\nSelect an attribute/text: "))
(= (length Ent) 2)
(wcmatch (cdr (assoc 0 (setq EntProps (entget (car Ent)))))
"ATTRIB,TEXT"
Ent
(= (cdr (assoc 0 EntProps)) "ATTRIB")
(setq LastPoint (cadr Ent)
LastEnt (entmakex
(cons
(cons 0 "TEXT")
(subst
(cons 73 (cdr (assoc 74 EntProps)))
(assoc 74 EntProps)
(subst
(cons
10
(cdr
(assoc
(= 0 (cdr (assoc 72 EntProps)) (cdr (assoc 74 EntProps)))
10
11
EntProps
(assoc 10 EntProps)
(vl-remove-if
(function (lambda (g)
(vl-position (car g) '(-1 0 2 5 70 73 100 280 330))
EntProps
(setvar "LASTPOINT" LastPoint)
(command "._MOVE" LastEnt "" (cadr Ent) PAUSE)
(if (not (equal LastPoint (getvar "LASTPOINT")))
(progn (entmod
(subst (assoc 11 (entget LastEnt))
(assoc 11 EntProps)
(subst (assoc 10 (entget LastEnt)) (assoc 10 EntProps) EntProps)
(entupd (car Ent))
(entdel LastEnt)
(command "._MOVE" (car Ent) "" (cadr Ent) PAUSE)
(setvar 'OSMODE OS)
I hoped that changing these lines
to something like:
(command "._MOVE" (car Ent) "b" "0,0" "0,-0.442")
would do it, but it doesn't so I am a bit lost now.
Any help would be appreciated.
P
