Author Topic: Basic Block Manager  (Read 8171 times)
Basic Block Manager
« on: October 13, 2010, 08:26:01 AM »
This is basically embarrassing to post compared to Daniel's My Block Manager
Hopefully this could be a start for anyone who would like to improve it and post the improvements.
But it gives the basic idea of creating a tool palette with a ListView for inserting blocks using .NET.
I threw this together real quick and since I am having problems with my computer I could not really test it or did not spend time making it very useful.
This is what you get for not planning out the solution and sitting down and just start coding.
You can use the current file or an external file.
You can use the different views shown in the pic of the context menu.
Double click on the image then select the insertion point to insert the block
It must be the current drawing to produce images for blocks that do not have one. Once produced save drawing and the image will be saved with the drawing.
If you already have produced images for blocks you must close the palette and run the command "BasicBlockManagerShow" (just type "Basi" then Tab)
You can group them by Letters of the Alphabet
If you created drawings with a vertical like MEP you might want to filter out blocks that start with "Aec"
  ****************Edited************
I added the projects for C# and VB
« Last Edit: October 13, 2010, 10:20:20 AM by Jeff H »
Re: Basic Block Manager
« Reply #1 on: October 13, 2010, 08:30:02 AM »
C#
using System;
using System.ComponentModel;
using System.Drawing;
using System.Data;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace HpadCadBasicBlockManager
public partial class BasicBlockMangerPalette : UserControl
private bool viewGroups = false;
private static string dwgFileName = null;
public BasicBlockMangerPalette()
InitializeComponent();
private void FillListView()
this.lvBlocks.Items.Clear();
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
using (Transaction trx = db.TransactionManager.StartTransaction())
BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
foreach (ObjectId objID in bt)
BlockTableRecord btr = objID.GetObject(OpenMode.ForRead) as BlockTableRecord;
if (!(btr.IsLayout))
string blkName = btr.Name;
Bitmap blkThumbnail = btr.PreviewIcon as Bitmap;
                        if (blkThumbnail == null)
                            using (CreateBlockIcon cbi = new CreateBlockIcon(blkName))
AddListViewItem(blkName);
else
AddBlockImageToList(blkName, blkThumbnail);
AddListViewItem(blkName, true);
}// End foreach
trx.Commit();
}// End trx
}// End FillListView
private void FillListView(string fileName)
Database db = new Database(false, true) as Database;
db.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, true, null);
else
}// End foreach
trx.Commit();
}// End trx
private void AddBlockImageToList(string blkName,Bitmap blkThumbnail)
if (!(this.BlockLargeImage.Images.ContainsKey(blkName)))
this.BlockLargeImage.Images.Add(blkName, blkThumbnail);
this.BlockSmallImage.Images.Add(blkName, blkThumbnail);
}// End AddBlockImageToList
private void AddListViewItem(string blkName,bool blkThumbnailExists)
ListViewItem lvi = new ListViewItem(blkName, blkName) as ListViewItem;
lvi.ToolTipText = blkName;
this.lvBlocks.Items.Add(lvi);
}// End AddListViewItem
private void AddListViewItem(string blkName)
ListViewItem lvi = new ListViewItem(blkName) as ListViewItem;
private void SetGroups(int column)
lvBlocks.Groups.Clear();
List<string> groups = new List<string>();
foreach (ListViewItem item in lvBlocks.Items)
   string groupName = item.Text.Substring(0, 1).ToUpper();
   if (groups.Contains(groupName))
  item.Group = lvBlocks.Groups[groupName];
   else
  groups.Add(groupName);
  item.Group = lvBlocks.Groups.Add(groupName, groupName);
#region "Context Menu Code"
        private void BlocksContextMenu_Opening(object sender, CancelEventArgs e)
            this.LargeIconToolStripMenuItem.Checked = false;
            this.DetailToolStripMenuItem.Checked = false;
            this.ListViewToolStripMenuItem.Checked = false;
            this.SmallIconToolStripMenuItem.Checked = false;
            this.TileViewToolStripMenuItem.Checked = false;
            this.useCurrentFileToolStripMenuItem.Checked = false;
            this.ChooseFileToolStripMenuItem.Checked = false;
            switch (this.lvBlocks.View)
                case View.LargeIcon:
                    this.LargeIconToolStripMenuItem.Checked = true;
                    break;
                case View.Details:
                    this.DetailToolStripMenuItem.Checked = true;
                    break;
                case View.List:
                    this.ListViewToolStripMenuItem.Checked = true;
                    break;
                case View.SmallIcon:
                    this.SmallIconToolStripMenuItem.Checked = true;
                    break;
                case View.Tile:
                    this.TileViewToolStripMenuItem.Checked = true;
                    break;
            ShowGroupsToolStripMenuItem.Checked = viewGroups;
            if (dwgFileName == null)
                this.useCurrentFileToolStripMenuItem.Checked = true;
            else
                this.ChooseFileToolStripMenuItem.Checked = true;
        }// End BlocksContextMenu_Opening
private void LargeIconToolStripMenuItem_Click(Object sender, EventArgs e)
this.lvBlocks.View = View.LargeIcon;
private void SmallIconToolStripMenuItem_Click(Object sender, EventArgs e)
this.lvBlocks.View = View.SmallIcon;
private void DetailToolStripMenuItem_Click(Object sender, EventArgs e)
this.lvBlocks.View = View.Details;
private void ListViewToolStripMenuItem_Click(Object sender, EventArgs e)
this.lvBlocks.View = View.List;
private void TileViewToolStripMenuItem_Click(Object sender, EventArgs e)
this.lvBlocks.View = View.Tile;
private void ShowGroupsToolStripMenuItem_Click(Object sender, EventArgs e)
viewGroups = (!(viewGroups));
lvBlocks.ShowGroups = viewGroups;
ShowGroupsToolStripMenuItem.Checked = !ShowGroupsToolStripMenuItem.Checked;
SetGroups(0);
private void ChooseFileToolStripMenuItem_Click(object sender, EventArgs e)
OFD.Filter = "Block Files|*.dwg;*.dwt";
OFD.Title = "Select Block File";
OFD.Multiselect = false;
OFD.ShowHelp = true;
OFD.CheckPathExists = true;
OFD.CheckFileExists = true;
OFD.FilterIndex = 1;
try
if (OFD.ShowDialog() == DialogResult.OK)
dwgFileName = OFD.FileName;
FillListView(OFD.FileName);
catch (System.Exception ex)
System.Windows.Forms.MessageBox.Show(ex.Message);
private void useCurrentFileToolStripMenuItem_Click(object sender, EventArgs e)
dwgFileName = null;
FillListView();
#endregion
private void lvBlocks_DoubleClick(object sender, EventArgs e)
string blk = lvBlocks.FocusedItem.Text;
                InsertBlock(blk);
            else
                InsertBlock(blk, dwgFileName);
        private void InsertBlock(string blkName)
            Editor ed = doc.Editor;
            using (DocumentLock docloc = doc.LockDocument())
                BlockTableRecord currBtr = db.CurrentSpaceId.GetObject(OpenMode.ForRead) as BlockTableRecord;
                if (!(bt.Has(blkName)))
                    return;
                ObjectId btrId = bt[blkName].GetObject(OpenMode.ForRead).ObjectId;
                PromptPointOptions ppo = new PromptPointOptions("/nSelect Insertion Point: ");
                PromptPointResult ppr = ed.GetPoint(ppo);
                if (ppr.Status == PromptStatus.OK)
                    Point3d insertPnt = ppr.Value;
                    currBtr.UpgradeOpen();
                    BlockReference bref = new BlockReference(insertPnt, btrId);
                    currBtr.AppendEntity(bref);
                    trx.AddNewlyCreatedDBObject(bref, true);
                trx.Commit();
        private void InsertBlock(string blkName, string fileName)
            Database extDb = new Database(false, true) as Database;
extDb.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, true, "");
            using (Transaction extTrx = extDb.TransactionManager.StartTransaction())
                    BlockTable extBt = extDb.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                    IdMapping map = new IdMapping();
                    ObjectIdCollection objIdColl = new ObjectIdCollection();
                    try
                        objIdColl.Add(extBt[blkName]);
                    catch
                        trx.Commit();
                        return;
                    db.WblockCloneObjects(objIdColl, bt.ObjectId, map, DuplicateRecordCloning.Replace, false);
                    BlockReference bref = new BlockReference(insertPnt,btrId);
                    trx.AddNewlyCreatedDBObject(bref,true);
                trx.Commit();
private void BasicBlockMangerPalette_Load(object sender, EventArgs e)
this.lvBlocks.ContextMenuStrip = BlocksContextMenu;
this.lvBlocks.LargeImageList = BlockLargeImage;
this.lvBlocks.SmallImageList = BlockSmallImage;
FillListView();
this.lvBlocks.ShowGroups = viewGroups;
    public class CreateBlockIcon : IDisposable
        [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode)]
        private static extern int acedCommand(int type1, string command, int type2, string blockName, int end);
        public CreateBlockIcon(string blkname)
            acedCommand(5005, "BLOCKICON", 5005, blkname, 5000);
        #region IDisposable Members
        public void Dispose()
        #endregion
« Reply #2 on: October 13, 2010, 08:30:43 AM »
VB
Imports System.Collections.Generic
Imports System.ComponentModel
Imports System.Drawing
Imports System.Data
Imports System.Linq
Imports System.Text
Imports System.Windows.Forms
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.Interop.Common
Imports System.Runtime.InteropServices
Public Class BasicBlockMangerPalette
    Private viewGroups As Boolean = False
    Private Shared dwgFileName As String = Nothing
    Private Sub FillListView()
        Me.lvBlocks.Items.Clear()
        Dim doc As Document = DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Using trx As Transaction = db.TransactionManager.StartTransaction()
            Dim bt As BlockTable = TryCast(db.BlockTableId.GetObject(OpenMode.ForRead), BlockTable)
            For Each objID As ObjectId In bt
                Dim btr As BlockTableRecord = TryCast(objID.GetObject(OpenMode.ForRead), BlockTableRecord)
                If Not (btr.IsLayout) Then
                    Dim blkName As String = btr.Name
                    Dim blkThumbnail As Bitmap = TryCast(btr.PreviewIcon, Bitmap)
                    If blkThumbnail Is Nothing Then
                        Dim cbi As New CreateBlockIcon(blkName)
                        blkThumbnail = TryCast(btr.PreviewIcon, Bitmap)
                        cbi = Nothing
                    End If
                    Else
                        AddListViewItem(blkName, True)
                    End If
                End If
            Next
            ' End foreach
            trx.Commit()
        End Using
        ' End trx
    ' End FillListView
    Private Sub FillListView(ByVal fileName As String)
        Dim db As Database = TryCast(New Database(False, True), Database)
        db.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, True, Nothing)
            Dim bt As BlockTable = (db.BlockTableId.GetObject(OpenMode.ForRead))
                        cbi = Nothing
                    End If
                    Else
                    End If
                End If
            Next
            ' End foreach
            trx.Commit()
        End Using
        ' End trx
    ' End FillListView
    Private Sub AddBlockImageToList(ByVal blkName As String, ByVal blkThumbnail As Bitmap)
        If Not (Me.BlockLargeImage.Images.ContainsKey(blkName)) Then
            Me.BlockLargeImage.Images.Add(blkName, blkThumbnail)
            Me.BlockSmallImage.Images.Add(blkName, blkThumbnail)
        End If
    ' End AddBlockImageToList
    Private Sub AddListViewItem(ByVal blkName As String, ByVal blkThumbnailExists As Boolean)
        Dim lvi As ListViewItem = TryCast(New ListViewItem(blkName, blkName), ListViewItem)
        Me.lvBlocks.Items.Add(lvi)
    ' End AddListViewItem
    Private Sub AddListViewItem(ByVal blkName As String)
        Dim lvi As ListViewItem = TryCast(New ListViewItem(blkName), ListViewItem)
    Private Sub SetGroups(ByVal column As Integer)
        Dim groups As New List(Of String)()
        For Each item As ListViewItem In lvBlocks.Items
            Dim groupName As String = item.Text.Substring(0, 1).ToUpper()
            If groups.Contains(groupName) Then
                item.Group = lvBlocks.Groups(groupName)
            Else
            End If
        Next
#Region "Context Menu Code"
    Private Sub BlocksContextMenu_Opening(ByVal sender As System.Object, ByVal e As System.ComponentModel.CancelEventArgs) Handles BlocksContextMenu.Opening
        Me.LargeIconToolStripMenuItem.Checked = False
        Me.DetailToolStripMenuItem.Checked = False
        Me.ListViewToolStripMenuItem.Checked = False
        Me.SmallIconToolStripMenuItem.Checked = False
        Me.TileViewToolStripMenuItem.Checked = False
        Me.useCurrentFileToolStripMenuItem.Checked = False
        Me.ChooseFileToolStripMenuItem.Checked = False
        Select Case Me.lvBlocks.View
            Case View.LargeIcon
                Me.LargeIconToolStripMenuItem.Checked = True
                Exit Select
            Case View.Details
                Me.DetailToolStripMenuItem.Checked = True
                Exit Select
            Case View.List
                Me.ListViewToolStripMenuItem.Checked = True
                Exit Select
            Case View.SmallIcon
                Me.SmallIconToolStripMenuItem.Checked = True
                Exit Select
            Case View.Tile
                Me.TileViewToolStripMenuItem.Checked = True
                Exit Select
        End Select
        If dwgFileName Is Nothing Then
            Me.useCurrentFileToolStripMenuItem.Checked = True
        Else
            Me.ChooseFileToolStripMenuItem.Checked = True
        End If
    ' End BlocksContextMenu_Opening
    Private Sub LargeIconToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles LargeIconToolStripMenuItem.Click
        Me.lvBlocks.View = View.LargeIcon
    Private Sub SmallIconToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SmallIconToolStripMenuItem.Click
        Me.lvBlocks.View = View.SmallIcon
    Private Sub DetailToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles DetailToolStripMenuItem.Click
        Me.lvBlocks.View = View.Details
    Private Sub ListViewToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ListViewToolStripMenuItem.Click
        Me.lvBlocks.View = View.List
    Private Sub TileViewToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TileViewToolStripMenuItem.Click
        Me.lvBlocks.View = View.Tile
    Private Sub ShowGroupsToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ShowGroupsToolStripMenuItem.Click
        viewGroups = (Not (viewGroups))
        ShowGroupsToolStripMenuItem.Checked = Not ShowGroupsToolStripMenuItem.Checked
        SetGroups(0)
    Private Sub ChooseFileToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ChooseFileToolStripMenuItem.Click
        OFD.Multiselect = False
        OFD.ShowHelp = True
        OFD.CheckPathExists = True
        OFD.CheckFileExists = True
        OFD.FilterIndex = 1
        Try
            If OFD.ShowDialog() = DialogResult.OK Then
            End If
        Catch ex As System.Exception
        End Try
    Private Sub useCurrentFileToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles useCurrentFileToolStripMenuItem.Click
        dwgFileName = Nothing
        FillListView()
#End Region
    Private Sub InsertBlock(ByVal blkName As String)
        Dim ed As Editor = doc.Editor
        Using docloc As DocumentLock = doc.LockDocument()
                Dim currBtr As BlockTableRecord = TryCast(db.CurrentSpaceId.GetObject(OpenMode.ForRead), BlockTableRecord)
                If Not (bt.Has(blkName)) Then
                    Return
                End If
                Dim btrId As ObjectId = bt(blkName).GetObject(OpenMode.ForRead).ObjectId
                Dim ppo As New PromptPointOptions("/nSelect Insertion Point: ")
                Dim ppr As PromptPointResult = ed.GetPoint(ppo)
                If ppr.Status = PromptStatus.OK Then
                    Dim insertPnt As Point3d = ppr.Value
                    Dim bref As New BlockReference(insertPnt, btrId)
                    trx.AddNewlyCreatedDBObject(bref, True)
                End If
                trx.Commit()
            End Using
        End Using
    Private Sub InsertBlock(ByVal blkName As String, ByVal fileName As String)
        Dim extDb As Database = TryCast(New Database(False, True), Database)
        extDb.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, True, "")
                Using extTrx As Transaction = extDb.TransactionManager.StartTransaction()
                        Dim extBt As BlockTable = TryCast(extDb.BlockTableId.GetObject(OpenMode.ForRead), BlockTable)
                        Dim map As New IdMapping()
                        Dim objIdColl As New ObjectIdCollection()
                        Try
                            objIdColl.Add(extBt(blkName))
                        Catch
                            trx.Commit()
                            Return
                        End Try
                        db.WblockCloneObjects(objIdColl, bt.ObjectId, map, DuplicateRecordCloning.Replace, False)
                    End If
                    End If
                    trx.Commit()
                End Using
            End Using
        End Using
    Private Sub lvBlocks_DoubleClick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles lvBlocks.DoubleClick
        Dim blk As String = lvBlocks.FocusedItem.Text
            InsertBlock(blk)
        Else
        End If
    Private Sub BasicBlockMangerPalette_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Me.lvBlocks.ContextMenuStrip = BlocksContextMenu
        Me.lvBlocks.LargeImageList = BlockLargeImage
        Me.lvBlocks.SmallImageList = BlockSmallImage
        FillListView()
        Me.lvBlocks.ShowGroups = viewGroups
End Class
Public Class CreateBlockIcon
    <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, CharSet:=CharSet.Unicode)> _
    Private Shared Function acedCommand(ByVal type1 As Integer, ByVal command As String, ByVal type2 As Integer, ByVal blockName As String, ByVal [end] As Integer) As Integer
    End Function
    Sub New(ByVal blkname As String)
End Class
« Reply #3 on: October 14, 2010, 09:03:19 AM »
Now that I have the system up and running It needs improvements
1. Dynamic blocks and Attributes
2. Jig the Block for Insert
3. A better way of producing preview Icons
4. After double click the palette needs to lose focus
This was from a minute of messing with it and I sure there are more.
mohnston
  • CAD Programmer
« Reply #4 on: October 14, 2010, 07:52:46 PM »
Nicely done. Thanks for sharing.
I'll attach a class I use for jigging. It was put together from various approaches I've seen.
Sorry it isn't documented better. The arguments to the methods are strings because I designed it to be usable from VBA. (COM)
As far as getting the focus on the drawing editor from the palette goes, that's a problem I'm still living with.
I think there are solutions that work with earlier versions but I'm coding for 2011 and I'm stuck.
I've been working on a block manager too. . . . for about 10 years now.
Actually our company has been using it for about 8 years and it's a big time saver for us. I would encourage you to keep at it.
CAD Programming Solutions
« Reply #5 on: October 14, 2010, 08:17:32 PM »
this week is mid terms and I have not spent much time with it
But thanks alot for the jig implementation
« Reply #6 on: October 15, 2010, 05:27:07 AM »
Nice!  8-)
