Author Topic: Non-Explodeable blocks in 2006  (Read 4864 times)
whdjr
Re: Non-Explodeable blocks in 2006
« Reply #15 on: November 02, 2005, 03:44:46 PM »
is it pronounced whidjer or wahidjer?
Ummm yes, I'd like to buy a vowel please.
It is not pronounced any way.
William Harold DeLoach Jr
whdjr
« Reply #16 on: November 02, 2005, 03:46:52 PM »
I found long ago that testing for the availability of a property via vlax-property-available-p, testing its current state, and then changing the state was far slower than just putting the hammer down inside a error trap. Not recommended as a blanket technique, but for some things it dramatically drops prosessing times where applicable and beneficial (like processing tens of thousands of drawings via objectdbx). Use carefully, again, not a blanket solution.
So...Do you always advocate speed over safety? :-P
Bob Wahr
« Reply #17 on: November 02, 2005, 03:47:21 PM »
I don't do letters.  I'm going to pronounce it as something.  If you won't give your preferance, I get to choose.  As of now, you are Whidjer.
« Reply #18 on: November 02, 2005, 03:50:02 PM »
I believe I addressed that already.
:P
whdjr
« Reply #19 on: November 02, 2005, 04:34:06 PM »
Ok then Whidjer it is.   :lol:
whdjr
« Reply #20 on: November 02, 2005, 04:35:01 PM »
:P
:lmao:
MikePerry
« Reply #21 on: November 03, 2005, 03:35:06 AM »
Just out of curiosity, can any other this be used when you come across a block that cannot be exploded?  Not talking 2k6, but lower versions. There have been times when you have a block that is not exploded because of different x,y scales and other things of that nature.
Hi
Maybe take a look at system variable EXPLMODE.
Have a good one, Mike
DanB
« Reply #22 on: November 08, 2005, 12:40:14 PM »
Open the new block editor feature for the block in question and check the properties window>>Block>>Allow Exploding>>Yes/No
whdjr
« Reply #23 on: November 08, 2005, 01:39:31 PM »
Good find Dan.  :-)
