Author Topic: Non-Explodeable blocks in 2006  (Read 4861 times)
whdjr
« on: November 02, 2005, 01:45:01 PM »
Using the 'block' command in AutoCad 2006 it gives you the option to make your block "non-explodeable".  Does anyone know how to change a block that is set this way or know how to explode the block?
Re: Non-Explodeable blocks in 2006
« Reply #1 on: November 02, 2005, 01:49:45 PM »
dunno ... insert as *blockname ?
Bob Wahr
« Reply #2 on: November 02, 2005, 02:02:22 PM »
Sub BoomIt()
Dim objblk As AcadBlock
Dim objblks As AcadBlocks
Set objblks = ThisDrawing.Blocks
For Each objblk In objblks
  objblk.Explodable = True
Next objblk
« Reply #3 on: November 02, 2005, 02:08:18 PM »
There ya go ...
glee
« Reply #4 on: November 02, 2005, 02:41:47 PM »
How about just redefining the block and checking the allow to explode option?
You probably have good reasons not to do so.
So I'll mosey on along..
« Reply #5 on: November 02, 2005, 02:53:13 PM »
That sounds like a good reason to disable the check box ....  :whistle:
Bob Wahr
« Reply #6 on: November 02, 2005, 02:55:18 PM »
That's pretty much the same thing that I said glee.  If you want to explode a non-explodable block, you have to change it's definition so that it is explodable.
whdjr
« Reply #7 on: November 02, 2005, 03:02:52 PM »
Sorry, doesn't work Keith.
Sub BoomIt()
Next objblk
Using your example Bob I penned this in lisp:
((lambda (/ lst)
   (vlax-map-collection
     (vla-get-blocks
     '(lambda (x)
  (vlax-property-available-p x 'explodable)
  (eq (vlax-get-property x 'explodable) :vlax-false)
  (not (vlax-put-property x 'explodable :vlax-true))
I am talking about the block command not the wblock command.
Bob Wahr
« Reply #8 on: November 02, 2005, 03:07:55 PM »
I don't know whdjr (is it pronounced whidjer or wahidjer?) there's a whole bunch of curvy things in that code.  Not sure how mine helped produce that mess ;)
Glad you got it solved.  You did get it solved, right?
« Reply #9 on: November 02, 2005, 03:14:05 PM »
OT: forgive me.
I found long ago that testing for the availability of a property via vlax-property-available-p, testing its current state, and then changing the state was far slower than just putting the hammer down inside a error trap. Not recommended as a blanket technique, but for some things it dramatically drops prosessing times where applicable and beneficial (like processing tens of thousands of drawings via objectdbx). Use carefully, again, not a blanket solution.
e.g.
(   (lambda ( )
            (vla-get-blocks
           '(lambda (object)
                (vl-catch-all-apply
                   '(lambda ( )
                        (vlax-put-property
                            object
                            'explodable
                            :vlax-false
Coded blind.
PS: What was the local variable lst for Will, residual from an earlier version?
pmvliet
« Reply #10 on: November 02, 2005, 03:15:18 PM »
Just out of curiosity, can any other this be used when you come across a block that cannot be exploded?  Not talking 2k6, but lower versions. There have been times when you have a block that is not exploded because of different x,y scales and other things of that nature.
I can't find any examples right now, but it did spark my brain...
Thanks,
Pieter
Bob Wahr
« Reply #11 on: November 02, 2005, 03:19:47 PM »
No, that's a different issue.
« Reply #12 on: November 02, 2005, 03:21:17 PM »
If you open that block in an release of ACAD earlier than 2006 you can explode. Not elegant.....but it works.
Ron
« Reply #13 on: November 02, 2005, 03:30:05 PM »
Ummm yes, I'd like to buy a vowel please.
whdjr
« Reply #14 on: November 02, 2005, 03:43:24 PM »
<...SNIP...>
Originally after I changed the value to 'true' I saved it to a var so I could explode it before exiting the routine, but I decided against that and I guess I left the var by mistake.  Sorry, I will fix.
