Malfunction...as in the line @ 'PN is picking the wrong coordinates of the point in question to start from.
It doesn't do it all the time and thus far just that point.
What happens if you start a line with the coordinates of Point #40 as the origin? (not using the transpearent command)
The line starts from what i call the node or point. What I would consider the correct location.
From above "the coordinates of 40 at the node", the actual point or the insert of the text label component 40?
So, you're telling me i can change the location of the point, it's coordinates, by changing the text label component?
