Hello,
It there a way to add/insert an item/command in the default right click menu
without editing the cui? I dont want to create my own (I've seen code
here that allows me to do that). I want to use the default one.
It will be different everytime. Lets say I want to rotate my crosshair 45 degrees.
In my code to rotate the variable "snapang" to 45 degress I want code to also be
able to put/add/insert a command in the right click menu to rotate it back to 0.
Any ideas?
