I use Autocad map 2004 and I am just puzzled as to why this particular dwg behaves. In this dwg, I have a close lwpolyline polygon and 3 lines inside the polygon. At command prompt, I entered erase and use the cp for select objects and I chose all the end points of the closed lwpolyline polygon.
Command: e ERASE
Select objects: cp
First polygon point: end of
Specify endpoint of line or [Undo]: end of
3 found
It returns 3 objects. By right it should return 4 objects. Why is this happenning? Any ideas.
I also have written a function to selectby polygon and sometimes it returns a wrong number of objects. Any comments to improve this function is much welcome.
;; This set of codes is dervied from Kerry
;; wg:NewNameSelectionSet
;; USAGE:
;; (wg:NewNameSelectionSet "Name of SS")
;; Returns a vla-object of selection set
;; 26-12-05
(defun wg:NewNameSelectionSet(SelSetName / ssCollection)
(setq ssColection (vla-get-selectionsets GB:ActivedocumentObj))
(setq SelSetName (vlax-make-variant SelSetname))
(if (vl-catch-all-error-p
(vl-catch-all-apply 'vla-item (list ssColection SelSetName))
(vla-add ssColection SelSetName)
(vla-delete (vla-item ssColection SelSetName))
) ;_if
); wg:NewNameSelectionSet
(defun ListToSafearray (symVariableType lstValues / safValues)
(setq safValues (vlax-make-safearray symVariableType
(cons 0 (1- (length lstValues)))))
(vlax-safearray-fill safValues lstValues)
; safValues
) ;listToSafeArray
;; GetObjectsByPolygon
;; USAGE:
;; Arguments
;; GB:ActivedocumentObj - <VLa-object (active document obj)>
;; whatobjects - <List of dotted pairs of entities to filter>
;; eg. (list '(0 . "LINE"))
;; eg. (list '(-4 . "<OR")'(0 . "LINE")
;; '(0 . "LWPOLYLINE")'(0 . "POLYLINE")
;; '(-4 . "OR>")
;; PointList - <variant safearray 3D coords>
;; Mode? - <2> acSelectionSetfence
;; Mode? - <6> acSelectionSetWindowPolygon
;; Mode? - <7> acSelectionSetCrossingPolygon
;; Returns a list of the VLA-objects filtered objects
(defun wg:GetObjectsByPolygon-list
( GB:ActivedocumentObj whatobjects PointList
mode?
/ objects-list ssObj
filter_codelist filter_valuelist
filter_code filter_value
(setq ssObj (wg:NewNameSelectionSet "SS1")
filter_codelist (mapcar '(lambda (x) (car x)) whatobjects)
filter_valuelist (mapcar '(lambda (x) (cdr x)) whatobjects)
filter_code (ListtoSafearray 2 filter_codelist)
filter_value (ListtoSafearray 12 filter_valuelist)
(vla-SelectByPolygon ssobj mode? PointList filter_code filter_value)
(setq objects-list '())
(vlax-for eachobj ssobj
(setq objects-list(cons eachobj objects-list))
objects-list
) ;_ wg:GetObjectsByPolygon-list
