Author Topic: ManagedMapAPI.dll load assembly problem  (Read 6506 times)
Jeff H
Re: ManagedMapAPI.dll load assembly problem
« Reply #15 on: July 21, 2011, 08:27:04 AM »
If you look the dll's from the SDK they are nothing but empty methods.
Basiclly just the definition
They stripped out guts and left all you needed for your code to reference it and compile.
From SDK
[TypeDescriptionProvider("Autodesk.AutoCAD.ComponentModel.TypeDescriptionProvider`1[[Autodesk.AutoCAD.DatabaseServices.Line, acdbmgd]], acdbmgd")]
[Wrapper("AcDbLine")]
public class Line : Curve
[UnitType(UnitType.Angle)]
public double Angle
get
public Vector3d Delta
get
public Point3d EndPoint
get
set
[UnitType(UnitType.Distance)]
public double Length
get
public Vector3d Normal
get
set
public Point3d StartPoint
get
set
public double Thickness
get
set
public Line(Point3d pointer1, Point3d pointer2)
public Line()
protected internal Line(IntPtr unmanagedObjPtr, bool autoDelete)
internal AcDbLine* GetImpObj()
From AutoDesk Folder it messed up but you get the idea
// Type: Autodesk.AutoCAD.DatabaseServices.Line
// Assembly: Acdbmgd, Version=18.2.0.0, Culture=neutral, PublicKeyToken=null
// Assembly location: C:\Program Files\Autodesk\AutoCAD MEP 2012\acdbmgd.dll
using \u003CCppImplementationDetails\u003E;
using System;
using System.ComponentModel;
using System.Runtime.InteropServices;
namespace Autodesk.AutoCAD.DatabaseServices
      [Category("Geometry")] get
        AcGePoint3d acGePoint3d1;
        AcGePoint3d acGePoint3d2;
        return \u003CModule\u003E.AcGePoint3d\u002EdistanceTo(\u003CModule\u003E.AcDbLine\u002EstartPoint(this.GetImpObj(), &acGePoint3d1), \u003CModule\u003E.AcDbLine\u002EendPoint(this.GetImpObj(), &acGePoint3d2));
    public double Angle
        \u003CModule\u003E.AcDbLine\u002EstartPoint(this.GetImpObj(), &acGePoint3d1);
        \u003CModule\u003E.AcDbLine\u002EendPoint(this.GetImpObj(), &acGePoint3d2);
        \u0024ArrayType\u0024\u0024\u0024BY02N arrayTypeBy02N1;
        ^(double&) @arrayTypeBy02N1 = ^(double&) @acGePoint3d1;
        ^(double&) ((IntPtr) &arrayTypeBy02N1 + 8) = ^(double&) ((IntPtr) &acGePoint3d1 + 8);
        ^(double&) ((IntPtr) &arrayTypeBy02N1 + 16) = ^(double&) ((IntPtr) &acGePoint3d1 + 16);
        \u0024ArrayType\u0024\u0024\u0024BY02N arrayTypeBy02N2;
        ^(double&) @arrayTypeBy02N2 = ^(double&) @acGePoint3d2;
        ^(double&) ((IntPtr) &arrayTypeBy02N2 + 8) = ^(double&) ((IntPtr) &acGePoint3d2 + 8);
        ^(double&) ((IntPtr) &arrayTypeBy02N2 + 16) = ^(double&) ((IntPtr) &acGePoint3d2 + 16);
        return \u003CModule\u003E.acutAngle((double*) &arrayTypeBy02N1, (double*) &arrayTypeBy02N2);
        \u003CModule\u003E.AcDbLine\u002EendPoint(this.GetImpObj(), &acGePoint3d1);
        \u003CModule\u003E.acdbWcs2Ucs((double*) &arrayTypeBy02N1, (double*) &arrayTypeBy02N2, false);
        AcGePoint3d* acGePoint3dPtr = \u003CModule\u003E.AcDbLine\u002EstartPoint(this.GetImpObj(), &acGePoint3d2);
        __memcpy(@acGePoint3d1, (IntPtr) acGePoint3dPtr, 24);
        \u0024ArrayType\u0024\u0024\u0024BY02N arrayTypeBy02N3;
        \u003CModule\u003E.acdbWcs2Ucs((double*) &arrayTypeBy02N1, (double*) &arrayTypeBy02N3, false);
        ^(double&) @arrayTypeBy02N1 = ^(double&) @arrayTypeBy02N2 - ^(double&) @arrayTypeBy02N3;
        ^(double&) ((IntPtr) &arrayTypeBy02N1 + 8) = ^(double&) ((IntPtr) &arrayTypeBy02N2 + 8) - ^(double&) ((IntPtr) &arrayTypeBy02N3 + 8);
        ^(double&) ((IntPtr) &arrayTypeBy02N1 + 16) = ^(double&) ((IntPtr) &arrayTypeBy02N2 + 16) - ^(double&) ((IntPtr) &arrayTypeBy02N3 + 16);
        return new Vector3d(^(double&) @arrayTypeBy02N1, ^(double&) ((IntPtr) &arrayTypeBy02N1 + 8), ^(double&) ((IntPtr) &arrayTypeBy02N1 + 16));
        AcGeVector3d acGeVector3d;
        return new Vector3d(\u003CModule\u003E.AcDbLine\u002Enormal(this.GetImpObj(), &acGeVector3d));
      set
        int num = (int) \u003CModule\u003E.AcDbLine\u002EsetNormal(this.GetImpObj(), (AcGeVector3d*) (int) &param0);
        if (num != 0)
          throw new Autodesk.AutoCAD.Runtime.Exception((ErrorStatus) num);
      [Category("General")] get
        return \u003CModule\u003E.AcDbLine\u002Ethickness(this.GetImpObj());
      set
        int num = (int) \u003CModule\u003E.AcDbLine\u002EsetThickness(this.GetImpObj(), param0);
        if (num != 0)
    public override Point3d EndPoint
        return base.EndPoint;
      set
        int num = (int) \u003CModule\u003E.AcDbLine\u002EsetEndPoint(this.GetImpObj(), (AcGePoint3d*) (int) &param0);
        if (num != 0)
    public override Point3d StartPoint
        return base.StartPoint;
      set
        int num = (int) \u003CModule\u003E.AcDbLine\u002EsetStartPoint(this.GetImpObj(), (AcGePoint3d*) (int) &param0);
        if (num != 0)
      void* voidPtr = \u003CModule\u003E.AcHeapOperators\u002EallocRawMem(8U);
      AcDbLine* acDbLinePtr1 = (AcDbLine*) voidPtr;
      AcDbLine* acDbLinePtr2;
      // ISSUE: fault handler
      try
        acDbLinePtr2 = \u003CModule\u003E.AcDbLine\u002E\u007Bctor\u007D((AcDbLine*) voidPtr, (AcGePoint3d*) (int) &pointer1, (AcGePoint3d*) (int) &pointer2);
      __fault
        // ISSUE: method pointer
        // ISSUE: cast to a function pointer type
        \u003CModule\u003E.___CxxCallUnwindDelDtor((__FnPtr<void (void*)>) __methodptr(AcHeapOperators\u002Edelete), (void*) acDbLinePtr1);
      // ISSUE: explicit constructor call
      base.\u002Ector((IntPtr) ((void*) acDbLinePtr2), true);
    public Line()
      try
        acDbLinePtr2 = \u003CModule\u003E.AcDbLine\u002E\u007Bctor\u007D((AcDbLine*) voidPtr);
      __fault
    protected internal Line(IntPtr unmanagedObjPtr, [MarshalAs(UnmanagedType.U1)] bool autoDelete)
      : base(unmanagedObjPtr, autoDelete)
    internal unsafe AcDbLine* GetImpObj()
      return (AcDbLine*) base.GetImpObj();
BillZndl
« Reply #16 on: July 21, 2011, 10:00:33 AM »
Hmm, interesting...
The OP was talking about an already compiled assembly and I was thinking his problems were similar to what I experienced when netloading a project that I had updated from VS2005.
I was actually having multiple problems with compiler warnings, netloading problems and system security settings.
http://www.theswamp.org/index.php?topic=38392.msg436738#msg436738
http://forums.autodesk.com/t5/NET/Netload-giving-trouble/m-p/3049974#M23872
Again, as a beginner/part time programmer, I searched the web and by substituting the SDK files mentioned when building the project,
switching back to 3.5 net and adding the loadfromremotelocations switch to the acad.exe.config file took care of things i was having trouble with.
In the future I'll just keep my mouth shut and read the replies but then I do learn something everytime whether good or bad.  :laugh:
« Last Edit: July 21, 2011, 01:54:46 PM by BillZndl »
Jeff H
« Reply #17 on: July 21, 2011, 10:20:00 AM »
He was saying a new API.
You can build a application with 2008 or 2005 and load it 2012 but you cannot use the dll's for 2012 since they are built with a newer version of .NET.
